Old 10-18-2010, 08:18 PM   #1
Rich Rykowski
No brakes!!!!!!!!!!!!!!!!!!!!
Hi everyone, I have a 67' C-10 stepside ( all stock). Brake pedal turned to "mush" in 2 days and then "presto!" NO BRAKES!! Popped the lid on the master cylinder and the rear resevoir was "EMPTY"! Sounds like an easy one, huh? Blown brake line perhaps? Blown wheel cylinder maybe? Where did the fluid go? There are NO holes in any brake lines, the hubs were pulled and the wheel cylinders are BONE DRY!! Anyway, I bought a new master cylinder and installed it, filled it with fluid, called a freind to crack the bleeders and get it primed, and once again, "NOTHING"! The system WILL NOT prime!! Should I crack the nuts where the lines enter the master cylinder and bleed the master cylinder itself first? I'm at wits end here!!! HEEEEEELLLLLLPP!!!
Rich Rykowski is offline   Reply With Quote
Old 10-18-2010, 08:23 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: No brakes!!!!!!!!!!!!!!!!!!!!
Yep, it sounds like a good idea to crack the lines and bleed the master cylinder.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-18-2010, 08:39 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
yeah you have to bleed the master cylinder first. Wouldn't know it if I hadn't done it myself
........ Shouldn't you still have front brakes?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
