![]() Join Date: Oct 2010
How to lower a 1969 GMC truck ? ( front )
Just got a very original 1969 GMC 2wd truck with a stock 6 cy shift on the col
Lots space on the front and I would like to lower maybe 4 inches or so Any kits or any suggestions? Would like to do without making the ride hard Thank You for any pictures or links that You can send ty |
the boat guy
Re: How to lower a 1969 GMC truck ? ( front )
4" on mine. Cut the coils, a-arm kisses the bumpstop. Rides better than most old trucks I've ridden in.
or you can buy springs. or you can buy springs and spindles. get a swaybar! Won't lower the truck any but improves driveability 100% don't forget to get an allignment.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Burnouts are therapeutic
are you going to lower the front and not the rear? if so 4 inches is going to be a lot of rake.... deffinently get drop spindles plus springs for your desired drop if you want more than 2 inches,if it has drums on the front they don't make drop spindles for drums to my knowledge. a lot of guys on here use ECE http://www.earlyclassic.com/ for suspension and thats who I plan to use also.good luck and nice looking truck
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
Grandpa in the rustmobile...
GET A SWAYBAR DIY OR A KIT!!!
Then, depending on how low/and how much $ ya wanna spend.. Cut 1 loop off your stock springs then get an alignment Get drop springs then get an alignment Drop spindles and no alignment NEEDED but prolly a good idea if ya aitn got one in awhile... Or a combo
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Thank you for the ideas,,,If I just wana lower like 2.5 ,,,,or maybe 3 ,, Can I just get drop springs then get an alignment
looks like changing the spindles will be away to much for me ,,,look at this link,,,,,huge job ,,,,but perfct teaching tool http://67-72chevytrucks.com/vboard/s...d.php?t=354132 |
man changing the spindles is not that hard, you can do it. you have to pretty much take the spindle off anyway to change the springs/cut them . i would lean towards changing spindles and do a little cutting on the springs verse just cutting springs. you will still have alot of suspension travel with the spindles and it would ride better(hell in that case just like it rides now.
and it wont hurt to put disc brakes on it, much better brakes to make sure you are safe. |
I would change the spindles and front springs to get the height you want. (not that hard)and since your there, change out the ball joints. ( also not that hard) IMO, this is worth thinking about. that way you are good to go! cheers, Pat
Tot Roddin'
Check out my build thread in my signature (Project Blank Slate) and it is everything you will need to know about lowering your '69.
I installed 2.5" drop spindles matched with 2" springs upfront; upgraded to 6-lug disc brakes and then lowered the rear with a 6" drop spring. New shocks on all four corners and shock relocators in the rear.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
