Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-18-2010, 09:09 PM   #1
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Fuel Gauge is pegged past full
I bought and installed a new 0-90ohm autometer fuel gauge. Its all hooked up with a full tank of gas. As soon as I turned the key for the first time it pegged itself pass full. I went through an entire tank without it moving a cm. The original fuel gauge worked. I'm at a lost and tried everything. Any and all help is appreciated.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-18-2010, 11:04 PM   #2
raycow
Re: Fuel Gauge is pegged past full
First, make sure the gauge body or shell is grounded. If that doesn't do it. you probably have an open connection on the sender side of the gauge, that is, between the gauge terminal and the tank unit. As a test, ground the terminal (on the gauge) and see if the gauge goes to empty. If it does, work your way back along the wire until you get to the tank unit.
Ray
raycow is offline   Reply With Quote
