Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-18-2010, 11:21 PM   #1
Marv D
Registered Truck Offender
Marv D's Avatar
66 is ready for the track!!!!
Started this little 'engine swap' in February so I'd have a summer race car that didn't require the firesuit and all. well here it is cooling off and the pig is FINALLY ready to go do some T&T and working through the shift, throttle stop settings, delay, bal bla Electronics HA!!! what have I gotten myself in to!
welp, as promised, heres some update pictures.
Layout inside became a TOTAL re-wire, building a new dash (even has LED turn indicators and bright indicator and it all works!!! LOL)
Getting the electronics, Co2 bottle , and all at hand proved to be more up comlex than I dreamed. But bending up a 'tree' from 1-1/4" tubing worked out pretty good. OK....
Track is open for T&T this friday so with 2 seconds in the delay, and a 6000 rpm shift we'll see how much more it has to be slowed down :-)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-19-2010, 12:13 AM   #2
nxtruck
nxtruck's Avatar
Re: 66 is ready for the track!!!!
Looks great Marv!! I especially like the way you fabbed the airpan.
Good luck with it on Friday, and let us know how things go!!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 10-19-2010, 01:22 AM   #3
Super73
Super73's Avatar
Marv, it sure is prettier than my junk.. Can wait to see what she runs. I have a more recent motivation to get mine looking like something. (Thanks). It should be getting the 10 point CM cage here in the next couple months. Danielle and I are also in the process of looking for a new house to buy. When that happens and we get settled in, truck will get body work and a complete rewire. Not only do I have to try and keep up with you down the strip, but I need to make it look at least half as good as yours..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-19-2010, 08:24 AM   #4
nomrlz
nomrlz's Avatar
that is a nice lookin ride
nomrlz is offline   Reply With Quote
Old 10-19-2010, 08:41 PM   #5
Marv D
Marv D's Avatar
Thanks guys. Yeah Chris,, I have to order another box of foam. The 'remnants' I found to make the top of the airpan seal look a little tattered. But the lexan airpan is one of my 'things' It works great. Lexan is such cool stuff. Bend it 90° in a sheet metal brake, shear it with a shear, glue it together with plastic glue, use 100% silicone to seal it and it makes a darn near indestructable air pan.
I think I'll have to haul over to speedworld and beg Rich to give me a 10.0 tech and turn this thing loose just for a few passes. ;-)
Shaun,, I have a 12 circut ARC touch panel in the Nova (and love it) and even tho I kept the trucks fuse block for the turn signals, lights and such, I put a 8 circuit touch panel (activated by the key) to operate the delay, fuel pumps, H20 / fans, trans cooling fan,start, ignition, etc. Comes with enough wire to do a normal race car. Only problem with them is you HAVE to find some way to de-activate it or the lighted panel will drain the battery in just a few days.
Old 10-19-2010, 10:11 PM   #6
shortbed70
shortbed70's Avatar
WOW Marv looks sweet. Cant wait to hear how things go. Good luck and get some video of it please....
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-19-2010, 11:11 PM   #7
dbmx66
that is one very nice piece of machinery right there
dbmx66 is offline   Reply With Quote
Old 10-23-2010, 12:44 AM   #8
Marv D
Marv D's Avatar
Welp,, first pass I took it nice and easy just feeling everything out. Disabled the throttle stop, changed from a timed shift to shift by rpm, set the 1-2 & 2-3 shift to 5800. Brakes pulled HARD to the right coming up to stage so was goiing to make a nice soft pass. launched at 1/2 throttle, rolled into it slowly till it shifted 1-2,,, then rolled it to the floor to just about 1200'. Went 11.06 lifting to 119mph. Was just easy on the brakes on the top end and she slowed down fine. Tech didn't whine so... 2nd pass were gonna let it eat :-)
reset the shift for a 1-2 of 6500 and a 2-3 at 6800 (love the Dedenbear box!!) reset staging rpm to 4800 so it doesn't flash the converter too hard (traction was 'iffy')
Rolled in to stage, off the button on the top bulb, mat the throttle and.... BANG, broke the left axle instantly at launch. Destroyed the aerospace caliper, rotor, but the bearing retainer did it's job and kept the wheel in place. Was a little spookey there sideways and no brakes, but got it out of the groove and stoped without incident (puking brake fluid every time I even thought touching about the brake pedal). Other than having only 1 wheel drive and NO brakes,, was able to limp it back to the pit and into the trailer. So tomorrow will assess the damage and start working up the order for a set of Mark Williams axles. That's the only axle I havent been able to tear up!!!
Old 10-23-2010, 01:38 AM   #9
Super73
Super73's Avatar
Nice numbers for an easy pass. Sorry to hear about the brakage, but I'm sure you'll have it back together soon enough. I'm gonna have to look in to a Deadenbear at some point..
Old 10-23-2010, 09:07 AM   #10
nomrlz
nomrlz's Avatar
sorry to hear of the carnage. good to hear nuttin serious happen. was expecting you to say it tapped the wall after the axle snapped like usually happens
Old 10-23-2010, 09:52 AM   #11
nxtruck
nxtruck's Avatar
Hate to hear you broke it, but it could have been a lot worse.
Sounds like some good numbers for an easy pass. Let us know when you get it put back together and make some hard passes with it!
Chris
Old 10-23-2010, 09:54 AM   #12
Marv D
Marv D's Avatar
This the the 2nd axle I've broke in the truck, and lost one in the Nova a few years ago. Been REAL fortunate,,, the stars were aligned just right and (knocking hard head against wooden desk,,,, ) and have never been into the wall.
And I was worried if the locker was going to take the stress... LOL
Old 10-23-2010, 11:30 AM   #13
noonzor
truck looks amazing marv! thats too bad about the breakage, sh*t happens eh? haha
hope your back up soon!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 10-25-2010, 09:53 AM   #14
Marv D
Marv D's Avatar
Wow, when I said it exploded an axle,,,,, I can't say as I've ever seen one shatter like this and only be TWO pieces (that I could find anyways. Sure there is more in the bottom of the case)
http://www.small-block-chevy.com/ima...2010/axle2.JPG
Old 10-25-2010, 01:31 PM   #15
noonzor
wow.....
Old 10-25-2010, 04:54 PM   #16
Super73
Super73's Avatar
Marv,
I think your axle is broken...
Again, sorry to see/hear about the carnage..
Old 10-25-2010, 11:34 PM   #17
nxtruck
nxtruck's Avatar
That 434 ain't playin', Marv!!
Chris
Old 10-26-2010, 03:19 PM   #18
Marv D
Marv D's Avatar
I think it should be around what I had hoped for once I get everything sorted out Chris. That's if I can keep the thing together!
Old 10-26-2010, 03:28 PM   #19
dbmx66
how many ponies are you thinkin with that 434?
Old 10-26-2010, 04:12 PM   #20
Super73
Super73's Avatar
If this is the one he had me do a performance trends engine analyzer on, I think it made almost 800hp on an engine dyno..
Old 10-26-2010, 09:21 PM   #21
Marv D
Marv D's Avatar
That was the one currently in the Nova Shaun, this was it's predecessor,, the devils motor. Made '666' on the same reputable Superflo in Tucson.
Old 10-26-2010, 11:57 PM   #22
nxtruck
nxtruck's Avatar
Well Marv, keep us up to speed on it. I'm curious to see what it runs on a good pass!! Once you get the bugs worked out of it, it'll be good to go. Hopefully, you don't have any more bugs hiding in it!!
Chris
Old 10-27-2010, 12:34 AM   #23
Super73
Super73's Avatar
Marv, would you mind pm'ing me the specs on this motor at the 666 mark.. I'd like to see how it compares to mine via perf trends..
Old 10-27-2010, 07:11 AM   #24
djracer
djracer's Avatar
Marv what kind of rear are you running in the truck? What brand of axle and spline count? I have always run 35 spline moser stuff in 9 inch rears and I have never broken an axle Knock on wood. I have seen one of my buddies break a strange 33 spline but it was a really old race car.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-27-2010, 08:24 AM   #25
swb85
On a budget like Fred Sanford
swb85's Avatar
Same here. I beat the wee out of mine (in a heavy 3-pedal car even) and have had great luck so far.
Looks like it's gonna be a fun ride with the stops pulled out Marv!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
