10-19-2010, 12:22 AM | #1 |
What have you done with interior after tank removal?
Title pretty much sums it up...after moving the gas tank from the cab, what has everyone done to "finish" the job? All I have seen is carpet kits to cover a tank, but nothing to cover the back wall of the cab with no tank in place.
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
10-19-2010, 12:24 AM | #2 |
Master Procrastinator
Re: What have you done with interior after tank removal?
good thread I'm in
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
10-19-2010, 12:41 AM | #3 |
70+ ( Old Skool Club )
Me too, lets see some pics !!!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-19-2010, 12:46 AM | #4 |
A Texan and two Canadians walk into a thread...
Sorry, couldn't help it. But yes, pics would be faaantastic! For what it's worth, I'm talking more about just basic upholstery work, not stereo equipment. All my audio will be under the seat, not behind it, so I'm curious what people have done to make it look "presentable."
10-19-2010, 12:51 AM | #5 |
Heres what I did...put something in front of it. I cant remember, but someone else took some plywood and carpeted it and attached it to the back. Looked very clean.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car Last edited by Bad70sbchevy; 10-19-2010 at 12:54 AM. |
10-19-2010, 12:54 AM | #6 |
[QUOTE=shiner2001;4248173]A Texan and two Canadians walk into a thread...
QUOTE] hahahaha I hadn't actually thought about this until you posted this thread, already have the filler hole patched so hopefully some good pics come in, not a big stereo guy either, but if it were done nicely I could make the neighbors hate me some more with even louder country than I play already
10-19-2010, 04:27 AM | #7 | |
[quote=tantrumpipeline;4248190]
So far I'm thinking about a carpet or vinyl covered piece of fiberboard (like peg board, sans holes), but until I pull my tank or see what others have done, I don't really know what kind of "shapes" I'll be needing to create, and hence not 100% on what material I'll be working with. I'm also thinking of making custom door panels out of the same or a similar material, so it could work out well to make this piece and them at the same time and tie it all together.
10-19-2010, 05:36 AM | #8 |
I am interested in seeing what others have done as well. I haven't even seen a carpet kit that goes all the way to the back wall.
67 5.3L Build |
10-19-2010, 05:51 AM | #9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=426572 Look at 1ATony's post and link. On their website they tell you to make a note or tell your salesperson if you have removed the gas tank so that they can cut the carpet longer. I haven't spoken to them yet, but it seems like that's the way to go...
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" Last edited by shiner2001; 10-19-2010 at 05:52 AM. |
10-19-2010, 05:59 AM | #10 | |
67 5.3L Build |
10-19-2010, 06:05 AM | #11 | |
I'm surprised no one makes a drop in kit with everything you need to "fill the void" (aesthetically, not physically) after you pull the interior tank. Or at least if they do, I haven't seen one. Although, I kinda like having to do something somewhat custom instead of just being able to mail order everything. Hey, that's what we're here for isn't it?
10-19-2010, 06:23 AM | #12 |
CAN'T FIX NOTHIN
I'd like to have the carpet tank cover , but wouldn't think of removing my tank ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
10-19-2010, 07:52 AM | #13 |
Sorry, no pics. I cut a sheet of 1/4" masonite the width of the back wall of the cab and cut the height so it would be a tight fit. Covered it in black carpet to match the rest, then glued it to the back wall of the cab. Then cut two pieces for the corners, covered them in black carpet and mounted 6 x 9 speakers in them.
How 'Bout them Dawgs! '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
10-19-2010, 08:03 AM | #14 |
I was looking at http://www.roddoors.com/pages/rearcabcovers.html but they dont have any pics? I was looking for something that wrapped around and the pics they show of the 60-66 looks like it does.
10-19-2010, 08:04 AM | #15 |
'70 C-10 Primer
Why not just move the seat back and make some room in these cramped cabs?
"The difference between stupidity and genius is that genius has its limits." Albert Einstein |
10-19-2010, 08:11 AM | #16 |
I had the interior shop make a panel to go back there. The ones on the sides have 6x9 speakers in them. He just covered it with leather. I like the way it turned out. It finished the interior off.
10-19-2010, 09:01 AM | #17 |
Tried to figure out what to do with the spare
10-19-2010, 11:18 AM | #18 |
Old member
Here is a couple of mine.
Placed the speakers and amp back there.
10-19-2010, 11:20 AM | #19 |
Well believe it or not, the seat is already as far back as it will go as is even with the tank. If you look at the clearance between the seat and back wall, youll know what I mean. I wish it did being 6'3" myself
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
10-19-2010, 11:41 AM | #20 |
Old member
Taking the tank out of one of these trucks will not give you any more leg room. The seat back hits the upper part of the cab where the window is. The only reason for removing the tank is smell of gas in the cab and for me I didn't like the fuel pump in the tank behind my seat.
The body panel above the speakers will not let a seat go back any farther. If you could come up with a way of removing it and then you could get more leg room.
10-19-2010, 11:53 AM | #21 |
... enjoyed the extra leg room
10-19-2010, 12:05 PM | #22 |
VA72C10
Porterbuilt on here makes metal panels for this area....
Looking for a 67-72 swb or blazer project in or around VA. |
10-19-2010, 02:57 PM | #23 |
That is the first I have seen of that and is EXACTLY what I am talking about. Sweet.
10-19-2010, 03:26 PM | #24 |
10-19-2010, 03:30 PM | #25 |
Porterbuilt's panels look like a perfect way to add a gun compart... ERRRRRRRR UUUHHHHHH, I mean a second glove box.
