Old 10-19-2010, 05:59 AM   #1
shiner2001
shiner2001's Avatar
Question Headlight relay upgrade...am I missing something here?? $$??
The benefits to upgrading to a relay switched headlight is obvious, but are the premade kits that you can buy from any of the aftermarket companies that range from about $40 up to over $100 anything more than a couple of relays, some wire and terminals? I think some of them have plugs for the headlights so you don't have to use female spade terminals...but come on now. Am I missing something here? Not knocking the kits, I can definitely see how some people would rather buy one that build one, just wondering if I was missing something obvious here...
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-19-2010, 07:22 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Headlight relay upgrade...am I missing something here?? $$??
The M&H kit has all the original heavy looms that cross over radiator and over the cowl, new bulk head connectors & they use all the factory wire colors, and connectors and build them to original specifications.
But yes, you can probably fab something up for allot less, using your "mint" 40 year old wires, connectors etc.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-19-2010, 07:22 AM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Kits=plug and play.......
Makin them= having all the right stuff to make it + know how........
Its just easier with plug and play for most.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 10-19-2010, 09:32 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I just upgraded the Green '67. I got the relays from an F-250 over at the salvage yard. (I actually picked up three sets) I spliced them into my original wiring with no problems. Just be sure to clean all of the contacts in the light circuit, including the dimmer switch connector. (it is usually the worst). I also added a ground strap from the engine to the frame and from the frame to the core support. Made all the difference in the world... No reason you can't do it this way if you take your time and do it right. For anyone who doesn't have the time, or doesn't want to take the time, buy aftermarket....
LockDoc
Leon
Old 10-19-2010, 10:20 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Seems like someone, somewhere on this site would have a schematic of the circuitry and a suggested list of parts (relays) to use. I can do the labor, but I'm no good at creating the circuitry.
Member Nr. 2770
Old 10-19-2010, 11:13 AM   #6
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Headlight relay upgrade...am I missing something here?? $$??
The relay's can be bought at O-rileys for less than $5.00 a relay that's a 40 amp. Good for 4-55 watt bulbs. The schematic is general but it works.
Low beam:
wire from dimmer switch is hooked to 86 on relay.
87 goes to low beam of head light
85 is a ground
30 is the 12 volt power from battery.
High beam is wired the same. I jumpered my 12 volts off of the low beam.
Here is mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-19-2010, 11:16 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's one for the two headlight system.
And I found the one for the four light GMC
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-19-2010, 12:03 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if this was on the electrical forum, then all the info would be right there.
It is easy for ppl with a little basic understanding of electricity to do.
If you are afraid of a butt conector, then get the premade kit.
Old 10-19-2010, 12:11 PM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
I added relays to my headlights when I installed a new wiring harness. The relay stuff is easy. I mounted my relays to the core support behind the battery tray.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 10-19-2010, 12:48 PM   #10
OldCreek
OldCreek's Avatar
Items needed to do it yourself:
Relay...or 2
Wiring
Butt end connectors/spade connectors
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 10-19-2010, 01:01 PM   #11
Kiwi
Kiwi's Avatar
You should simplify and buy the #MX01132 pre-made headlight wiring harness (with relays) from Classic Industries.
A few weeks ago a similar thread (regarding HID headlights and upgraded wiring) was going around. Have a look as it will provide some added info. Attached is a photo of the post that I made on that tread ... including info on the pre-made harness with relays.
http://67-72chevytrucks.com/vboard/s...d.php?t=419322
Kiwi is offline   Reply With Quote
Old 10-19-2010, 02:19 PM   #12
Andy4639
Old member
Andy4639's Avatar
Two relays and a couple of but connectors and some small peices of wire. Less than $10.00 total and about 30 minutes of your time. Once installed the only wires seeing the load is the new battery wire to relay and the head lights. This wire is heavy enough to handle it.
The head light switch was the main concern.
Just as I did my driving lights off the parking lamps the load is no longer ran through the switch.
Old 10-19-2010, 02:32 PM   #13
69sixpackbee
http://www.madelectrical.com/electri...adlights.shtml
69sixpackbee is offline   Reply With Quote
Old 10-19-2010, 02:58 PM   #14
Kiwi
Kiwi's Avatar
I have used many items from MAD Electrical before. Quality stuff at a fair price.
Recently I upgraded my '71 with a more modern 12SI alternator, MAD alternator wiring kit, new Xenon headlights, and the updated headlight wiring kit (with relays) from Classic Industries. The project was very straightforward and the results are great. Installing the pre-made headlight harness was a cinch. Simplify and buy a pre-made harness rather than trying to cobble something together yourself.
