Old 10-19-2010, 12:41 PM   #1
P4B
67 C10 Wiper Motor
Hi All.
New here. I have a 67' C10 short box with a seized wiper motor. I'm looking at changing it. Question is how do you get at the linkage under the cowl ? Does the cowl have to be removed ?
Thanks.
randy.
P4B is offline   Reply With Quote
Old 10-20-2010, 10:09 AM   #2
P4B
Re: 67 C10 Wiper Motor
Anyone ???
Old 10-20-2010, 12:04 PM   #3
67gmcstepside
Yes, carefully pull off the wiper blades, remove the cowl and you will see the linkage is held on with a snap fastener. You lift the end of the fastener and slide it up and the linkage can come off the wiper motor.
67gmcstepside is offline   Reply With Quote
Old 10-20-2010, 12:08 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There are three nuts that hold the motor onto the cowl, and you gotta get them from underneath the cowl. It's up and behind the radio. Gonna have to get limber and flexible. You'll need 'em both.
Member Nr. 2770
Old 10-20-2010, 12:14 PM   #5
P4B
That's great, Thanks. I was hoping not to have to remove the cowl. Afraid of breaking the paint around the screws and bolts, oh well. Limber and flexible ?? It's been a long time since I've had to hang upside down on the seat to get under the dash...
Randy.
Old 10-20-2010, 08:43 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I have removed a couple of them without removing the cowl. I just put some masking tape around the openings above the motor arm and pry the clip off with a screwdriver. Have a magnet handy and when it starts coming off hold the magnet against it so it doesn't go flying. Lift the arms off with a stiff wire with an angle bent on one end. Remove the motor, install the new one and replace the arms and clip. The easiest way to replace the clip is to hold it in place with the magnet and push it on with the screwdriver...
Works for me.
LockDoc
Leon
Old 10-21-2010, 09:36 AM   #7
P4B
Thanks Lockdoc
I'll give that a try tomorrow.
Randy.
Old 10-21-2010, 10:34 AM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There is a tool that you can get that will lift the wiper arms off of their posts. Sure makes it a lot easier than trying to pry them off without getting them cocked in a bad angle. NAPA has had it.
Member Nr. 2770
Old 10-21-2010, 11:31 AM   #9
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Works for me.
LockDoc
Dang that is alot of tedious work just to change a wiper motor!!! hahah Sounds like fun though!
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
