![]() Join Date: Oct 2006
brake booster question
Will a 7" or 8" dual diaphram brake booster be good for a 1960 with a L6?
Will it give sufficent vacum or should I just run non power disc? I have limited space and don't think a full size booster will fit. This is my next project as I just spilt the brakes to a dual circuit drum/drum master. So No rush just looking for addvice Thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: brake booster question
Do you know how much vacuum your 235 makes? The '82-'87 S10's came with either a 9 or 10 inch dual diaphram booster.
If you can find out what your vacuum is, I can check mine to see how much it takes to operate mine.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Thanks guys my '60 has a 250 in it and I truthfuly don't know what vacum it makes
1962 C-10
Hey Sal. My guess would be that your 250 will produce plenty of vac to run that booster. 250 was a common engine option in the 70's and early 80's with power brakes. Shouldn't be a problem... Good luck! JC62
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
hey Jose howz it going ? Captinfab I sold my stepside to my wifes son and told him that if was going to add p/s or p/b to hit you up. 63GenIII thanks for the offer !
Got a 7" at a local swap meet I'll give that a shot ,I know that some 72's came with non power disc brakes so hopefuly it works out
Captinfab you mentioned using a S10 booster , do the push rods on those boosters need to ne modifiyed?
60-66 Nut
Yes you will need to modify most any OEM booster pushrod to be able to connect it to your pedal
