Old 10-19-2010, 04:02 PM   #1
gopokes
gopokes's Avatar
Removing trailing arm u bolts
I have been trying for two days to get the nuts of the ubolts holding the trailing arm to the axle. Been soaking them with PB blaster every night and no luck yet. I have tried a breakover handle and 3 foot cheater, and an impact wrench and am getting nowhere. I would like to be able to get them off without cutting the ubolts if possible, but am about to break out the cutting wheel. Anyone have any other ideas?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 10-19-2010, 04:04 PM   #2
faribran
Re: Removing trailing arm u bolts
the ole' blue tool..... the trusty torch.... has worked for me in may cases...
faribran is offline   Reply With Quote
Old 10-19-2010, 04:04 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Cut them and buy new.
40 year old u-bolts holding the rearend under your truck isn't that great of an idea anyway.
Keith
Convert to disc brakes.
Old 10-19-2010, 04:27 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
They can be real stubborn, I pull a rear at a junk yard the other day. I went to the yard a week ahead and sprayed the u-bolts with penetrating oil and it still took everything I had to break them loose with a 24" breaker bar. If I weren't in a junkyard I would have used a torch or cutoff wheel.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-19-2010, 04:30 PM   #5
gopokes
gopokes's Avatar
That's true, I was afraid this was the route I was going to have to take. Any suggestions on who has the best price? I found them at LMC for $15 a piece plus shipping, seems reasonable.
Old 10-19-2010, 04:32 PM   #6
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
You may want the smoke wrench anyway. Once you get the nuts off you could find that the leg of the u-bolt has rusted into the arm itself.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-19-2010, 04:47 PM   #7
stich626
u can get them local at any spring place that services leaf springs..
look up big rig surpliers..
stich626 is offline   Reply With Quote
Old 10-19-2010, 04:55 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
as mentioned...cut and get new...
with how low you're going have you considered lowering blocks? If so, they come with new proper sized U-bolts
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-19-2010, 05:01 PM   #9
gopokes
gopokes's Avatar
I hadn't been thinking about lowering blocks since I decided to bag it. I was thinking the blocks only helped on static drops, brain isn't working right now. Wouldn't that just let me have a little more air in the bags at a lower height?
Old 10-19-2010, 05:07 PM   #10
ozman3803
Just did some googling because i'll be shopping for some to. Dsubin is a website that custom makes them and looks like about 10 bucks a piece.
ozman3803 is offline   Reply With Quote
Old 10-19-2010, 05:15 PM   #11
cdowns
cdowns's Avatar
ubolts are available at local autopars stores,spring shops and trailer and boat supply places all with no shipping when buuying locallly. why wood anybody spend shipping money on them is a mystery
Old 10-19-2010, 05:29 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
yep, that's why I'm planning on a 2" block or even the 3" PB dropped trailing arms...so I can run more air at a nice low ride height and have a comfortable ride.
Old 11-27-2010, 02:05 PM   #13
rvn1038
Where is the best place to cut the U bolts? I have the U bolt nuts off but the legs are stuck in the trailing arm... How do I get the legs out after cutting? I want to reuse the trailing arm, just need to replace the bushing and U bolts.
rvn1038 is offline   Reply With Quote
Old 11-27-2010, 02:18 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
I cut it at the top of the axle right where it starts to angle over. Cut on both sides so it leaves basically two verticle posts left. Then you can take the axle out and you can pound out the leftover bolts from the top
