Old 10-19-2010, 04:05 PM   #1
72tutone
Bone Stock 350 Upper kit
To my knowledge this is a bone stock rebuilt 350. I have no idea the bore over size.
I can tell you it even retains the rochester Qjet 4bbl on it.
Will I be able to use this kit for this motor? 350 in it now with a TH350 LWB.
http://www.jegs.com/i/GM-Performance...96#moreDetails.
I know there is alot of discussion in regards to the vortec heads, but I didnt know if you can match that up with the block I have.
I would think with a mild cam xe268h or so that it would run decent.
Motor does have an HEI distrib.
Thoughts?
72tutone is offline   Reply With Quote
Old 10-19-2010, 04:29 PM   #2
MVHandy
Re: Bone Stock 350 Upper kit
I'd just call JEGS tech line and ask but, how sure are you of the condition of the bottom end?
MVHandy is offline   Reply With Quote
Old 10-19-2010, 07:38 PM   #3
oldno7
oldno7's Avatar
In my 72 fleet long, I have a 350 crate engine thats stock. I ended up putting a set of air flow research heads on it that are 195 intake ports with a 262 comp cam. I do have a hei dist, and a little 600 holley carb. It also has a victor jr intake(open port) whitch is odd to have on a stock motor with a little cam. You would prefer a airgap style. Any ways the best I've had it in the eigth mile is 8.97. Also i have a tci street fighter tranny and 4.56 posi rearend that relly launches on my et streets. You will be fine with the combo your looking at. If this is a street driven truck and you just want some pep you could put some gear in the rear. Also remember that torque is what you should focus on. good luck
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
