Old 10-19-2010, 05:02 PM   #1
wp silverado
can i get some help with mounting my gearbox?
when i got my 64 the steering was completely apart and in a box. i got the centerlink and tie rods setup but im struggling with mounting the box, i think im missing something. the box wont mount flush to the frame horn and i just dont see how this could work. if you could post some pictures or maybee describe this better to me id apreciate it. i can post up pics if you need them.
1967 c-10-built smallblock, backed by m-21, lowered
2005 silverado-tint, exhaust, lift, 35's
1964 c-10 shortbed project
wp silverado is offline   Reply With Quote
Old 10-19-2010, 05:06 PM   #2
slepysal
slepysal's Avatar
Re: can i get some help with mounting my gearbox?
is it manual or powwer ?post a pic and let us take a look
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-19-2010, 05:10 PM   #3
wp silverado
i believe its a power steering gearbox, also the steering shaft has been lengthened i believe if that helps.let me get a pic or two up
Old 10-19-2010, 05:29 PM   #4
slepysal
slepysal's Avatar
If the power steering was added on by the PO you need adaptor plates. Do a search "power steering" you can find a pic hope this helps
Old 10-20-2010, 12:03 AM   #5
Captainfab
60-66 Nut
If it is a power steering box you will need an adpater plate to space it out from the frame. This allows for the raised area on the backside of the box.
Old 10-21-2010, 09:40 PM   #6
wp silverado
si all i need is a power steering mounting kit??
here is my truck
here is my box
and this is my setup on the 67 just as a reference this is what i plan on doing, a ps setup with no pump
thanks again for any help
Old 10-22-2010, 12:51 AM   #7
Captainfab
60-66 Nut
Yes you will need an adapter plate to mount that power steering box on your '64 frame. If I may ask, why do you want a power steering box if you're not going to connect it to a pump?
Old 10-22-2010, 01:24 AM   #8
slepysal
slepysal's Avatar
The Captain is right . Do yourself a favor click the Power Steering Box Adapter Plates For Sale HERE tab
under captainfabs sig buy it install it and forget !!
Old 10-22-2010, 11:41 PM   #9
Captainfab
60-66 Nut
Thank You Sal
Old 10-23-2010, 08:30 AM   #10
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I'm wondering that also. PS with no pressure is harder to turn than a manual box.
Alan's Classic is offline   Reply With Quote
Old 10-23-2010, 03:01 PM   #11
wp silverado
alright thanks alot when im ready to slap it all on il grab a plate from you captain
as far as keeping this box its just simpler that way the shaft has already been cut for it and i dont want to waste 200 dollars on a new manual box not to mention it doesnt bother me the setup in the 67s not that hard
