10-19-2010, 07:09 PM | #1 |
Motor problems...
So lately when my truck shifts into a higher gear and its in the lower part of that gear everything will be very shaky. Also when I'm driving and have the gas pedal set at a certain point it will be going one speed and then start accelerating by itself until it shifts to the next gear without me moving my foot.
If anyone has had this similar problem or might know what it could be any help would be appreciated.
...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| 1986 Chevy Custom Deluxe Nothing like a square body http://67-72chevytrucks.com/gallery/...0&ppuser=45891 |
10-19-2010, 08:51 PM | #2 |
Robert Olson Transport
Re: Motor problems...
are you sure the part of shaky in the bottom end of the gear is not pre ignition?
10-20-2010, 09:48 AM | #3 |
1962 C-10
When's the last time the trucks had a tune-up. Plugs, wires, cap, rotor...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 Last edited by jchav62; 10-20-2010 at 09:48 AM. |
10-20-2010, 08:14 PM | #4 |
I just recently changed the plugs rotor and distributor cap. I also had thought it had to do with my fuel pump because it was staling out so I changed the pump and I've changed the fuel filter.
10-20-2010, 09:56 PM | #5 |
possible vacuum leak? that would cause the motor to idle high and when put in gear, want to accelerate without you touching the gas
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
10-23-2010, 12:56 AM | #6 |
Turns out that my plug wire was laying up against my headers and was causing it to miss fire. Also there is a possibility that my carb is caked up figuring its still the original one that's never been touched. Also the mixture control solenoid is bad.
So I'm going to have to get a new carb that will also pass smog. Does anyone know where to get either another Quadrajet or any other carb that's California smog exempt.
10-23-2010, 03:14 PM | #7 | |
