Old 10-19-2010, 07:46 PM   #1
dman1982
dman1982's Avatar
keeps jumping timing???
i got a 84 k10 4x4, my timing keeps jumping around on me, weve adjusted once about a month or so ago and ran fine, it jumped timing again and is starting to flood out, had to leave it at work a couple days....but got her home and wanted some advice before i start ripping her apart.
dman1982 is offline   Reply With Quote
Old 10-19-2010, 07:53 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: keeps jumping timing???
is the dizy hold down tight?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-19-2010, 07:57 PM   #3
dman1982
dman1982's Avatar
oh ya...thats was the first thing i checked
Old 10-19-2010, 08:00 PM   #4
BigBlocksRule
Loose/worn timing chain would be the next place I'd check.
BigBlocksRule is offline   Reply With Quote
Old 10-19-2010, 08:06 PM   #5
dman1982
dman1982's Avatar
ya thats what im thinking....they dont cost a whole lot either....any other suggestions? thats kindof a PITA job.
Old 10-19-2010, 09:39 PM   #6
dman1982
dman1982's Avatar
does anyone else have any other suggestion before i start tearing this thing apart?
Old 10-19-2010, 09:56 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
One, the harmonic balancer is shot. Two, the nylon gears on chain are starting to fail. Is vacuum constant on the HEI?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-19-2010, 10:05 PM   #8
dman1982
dman1982's Avatar
on not sure on the vacum but ill check that out tommorow....last time i checked it was all good
Old 10-19-2010, 10:07 PM   #9
dman1982
dman1982's Avatar
gchemist.....are you telling me about the harmonic balancer or telling me? lol how do i check it?
Old 10-19-2010, 10:23 PM   #10
nbpro
spark control module
distributor removal required to remove pick up coil. magnets shouldnt be cracked. while distributor is out check for knifedging on the drive gear.
nbpro is offline   Reply With Quote
Old 10-19-2010, 10:24 PM   #11
dman1982
dman1982's Avatar
im not sure if i have a spark control module....isnt that for fuel injection???
Old 10-19-2010, 10:25 PM   #12
DaSchlange
DaSchlange's Avatar
That's what I was thinking at first, but the module doesn't actually cause it do jump does it? I thought if the module went bad it just didn't fire at all.
DaSchlange is offline   Reply With Quote
Old 10-19-2010, 10:38 PM   #13
dman1982
dman1982's Avatar
i forgot to mention that this engine has about 200-300k on it...i do plan on dropping another engine into it...but thats going to be closer to spring
Old 10-20-2010, 01:11 AM   #14
gchemist
gchemist's Avatar
Your problem can be both. Grab the outside ring. Can you move it? Put a strap wrench on it. With that many miles, the nylon gears will break off at any time. A timing chain failure finished off the original 305 in my truck.
This happens when nylon coated gears fail!
Old 10-20-2010, 03:18 AM   #15
nbpro
not saying it's his problem just some thing to check
The Electronic Spark Control, also called the Knock Sensor, is an electronic device built by General Motors to help regulate the timing inside of the engine.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
post by gchemist
http://www.chevytalk.org/fusionbb/sh...hp?tid/176666/
http://67-72chevytrucks.com/vboard/s...d.php?t=416801
The ESC distributor used a 5 pin ignition module. The ESC distributor had two plugs coming out of the distributor, one plug going to the cap / coil assembly, and the other plug went to the spark timing controller
Old 10-20-2010, 06:16 AM   #16
LONGHAIR
The real problem with "jumping timing" on the ignition by a timing chain slip is that the cam timing is now late too. This is going to cause problems that are bigger than ignition.
The next issue is that it's not a simple "replace the gears and chain" type of thing. Those nylon teeth off of the cam sprocket had to go somewhere...... The oil pan and oil pump will be full of that junk.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-20-2010, 04:38 PM   #17
dman1982
dman1982's Avatar
well im going to be jumping into this project tommorow. dont have time today or i would be
Old 10-20-2010, 04:55 PM   #18
Cue-Ball
Cue-Ball's Avatar
Is the timing moving around if the vacuum advance is unplugged? If not, you could have a defective vacuum advance or a torn diaphragm. I'd also check the centrifugal weights in the distributor. They could be sticking, which would explain the timing being different from week to week (even if the vacuum advance is unplugged and determined not to be the problem). Definitely check those two things before you start ripping into the engine to check harmonic balancer and timing chain.
Cue-Ball is offline   Reply With Quote
Old 10-21-2010, 08:07 AM   #19
dman1982
dman1982's Avatar
hey cue ball...ill definetly check that before i start getting into all that stuff
Old 10-21-2010, 08:21 AM   #20
BigBlocksRule
^ you betcha, good advice.
There's not many things that are worse than doing a big tear-down or re-work and finding out the problem was much simpler and easier to fix!
Old 10-21-2010, 09:26 AM   #21
dman1982
dman1982's Avatar
bigblocksrule......i know exactly what you mean....ive encountered that way too many times...really freakin sucks...lol...but atleast you got new and extra parts sometimes lol
