Old 10-19-2010, 10:43 PM   #1
scubasteve16
scubasteve16's Avatar
Gas tank sending unit
Ok PO installed what I believe is a Blazer gas tank in my 64 Chevy Panel. I have a aftermarket fuel gauge that requires a 0-90 ohm fuel sending unit. The sending unit in the tank now is only a 30 ohm sending unit. I have tried to go to local parts stores to find a sending unit but they look at me like I am a idiot. I found a few units that have a 0-90 ohm but they are for a larger tank so thay are to big. The tank I have is what I believe is a 15 gallon or so because it was completely full and I drained 3 five gallon gas cans of fuel out of it. Any info on a fuel sending unit that will work would be great. It has to be a sending unit that has not only the sending unit wiring on it but the fuel line on it.
"If it throws you back in the seat when it shifts, it was slowing down before it shifted"
Disturbed Customs
1992 Chevy 1/2 ton 4x4 wore out 350
1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires
1950 Pontiac Chieftain Straight 8/Hydromatic tranny
scubasteve16 is offline   Reply With Quote
Old 10-19-2010, 11:28 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Gas tank sending unit
I'm not sure what vehicle you could pull one out of, but I recently installed a 90 ohm tank and am using the 30 ohm gauge. The tank that I used was out of a 91 Blazer. I removed 2/3 of the resistor wire for a total of 30 ohms left, rewound it and reinstalled it. It works great. That said, this stuff is not rocket science. You could probably get a sender out of a 91 and adapt it to your float - pickup combination. I looked around and found a guy in NY that said he could help me out for 200.00. I'm pretty cheap so I tried it myself. My tank was a 33 gall. I believe but they all work on the same principal.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-20-2010, 12:37 AM   #3
Captainfab
60-66 Nut
Without seeing the tank, it's hard to make a recommendation, but try one for a '69-'72 Blazer. One of the aftermarket truck parts suppliers would be your best bet. If that gas tank has a half round indentation for a spare tire, it is the original tank. The Blazer sending unit will work.
Old 10-20-2010, 11:35 AM   #4
gulffishin
gulffishin's Avatar
If it were me, I would buy an aftermarket 0-90 ohm sending unit ( I think autometer makes one) and install it next to the 0-30 ohm unit. Leave the fuel pickup line hooked to the 0-30 unit and hook your gauge to the 0-90.
gulffishin is offline   Reply With Quote
Old 10-20-2010, 07:10 PM   #5
scubasteve16
Well I gave Brotherstruckparts.com a call and they have a sending unit that will go right in my tank and is 90 ohm for 35 bucks shipped to my dorr so guess i got my answer just had to do a little research.
Disturbed Customs
Old 10-26-2010, 07:32 PM   #6
scubasteve16
Well looks like I am back on the hunt for a sending unit..... I spoke with a guy at Brothers and he told me the part number for the sending unit I needed and asured me they were in stock and I would have no worries I got online ordered it and few other things.... Got my order conformation and what do I see....Everythings in stock Except the one thing I need right now the sending unit.....So guess I wont be doing NO BUSINESS with Brothers in the future I am done with them...
Disturbed Customs
Old 10-26-2010, 08:00 PM   #7
lucifer
lucifer's Avatar
Cool Re: Gas tank sending unit
LMC sells one for the Blazer conversion tank I they have them in stock. Spoke with them today on that exact subject.
Lucifer
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 10-26-2010, 09:29 PM   #8
scubasteve16
Ya I called and spoke with them about one I am needing a 90 ohm sending unit and they couldnt tell me if theres was a 90 ohm or a 30 ohm sending unit.
Disturbed Customs
Old 01-25-2011, 02:02 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm trying to figure out what ohms my sending unit needs to be for this gauge:
http://www.summitracing.com/parts/SUN-CP8209/
66 C20 Service Truck:
Old 01-25-2011, 03:03 AM   #10
Captainfab
60-66 Nut
The description says that gauge is a 240 to 33 ohms fuel gauge.
Old 01-25-2011, 03:05 AM   #11
LostMy65
LostMy65's Avatar
So does that mean it will work with any sending unit between 33 and 240 ohms?
Old 01-25-2011, 03:09 AM   #12
Captainfab
60-66 Nut
No. That means that you will need a sending unit that reads 240 ohms when empty and 33 ohms when full. That's not a GM gauge/sending unit. I don't remember which OEM uses that one. You can get aftermarket sending units with that ohms range.
Old 01-25-2011, 03:12 AM   #13
LostMy65
LostMy65's Avatar
Okay, Thanks.
For now, my gas tank dipstick still works - aka: stick
