Old 10-20-2010, 12:34 AM   #1
72Cheyenne350
Blower Motor
I tested my blower motor by using some alligator clips and its running. When I try to turn it on from the lever inside it doesn't want to run, I changed the relay, made sure the ground and power are connected, changed out the fuses, but still a no go. Any tips on trouble shooting...I'm guessing I've done most of the simply steps. Thanks.
72Cheyenne350 is offline   Reply With Quote
Old 10-20-2010, 01:00 AM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Blower Motor
Faulty switch maybe?
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 10-20-2010, 01:59 PM   #3
raycow
Re: Blower Motor
You already know the motor is good and you know it isn't getting any power. So follow the route the power takes. Start at the fuse block. If you have power there, check at the switch, then the resistor. You have a break somewhere, and you just have to find it. Sorry, but there is no secret handshake on this one. You will have to do the grunt work.
Ray
raycow is offline   Reply With Quote
Old 10-22-2010, 04:55 PM   #4
72Cheyenne350
Re: Blower Motor
Thanks guys, I'll break out the wiring diagrams and tackle this one. Raycow, you sure there is no secret handshake? hahahhahahaha. I'll let you know what the progress is after this weekend.
