Old 10-20-2010, 11:29 AM   #1
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
LS Swap guys! What did you do for a speedo?
I may have asked before but please tell me what you all did with your speedo in the swap, CABLE-X? Electronic speedo?
If you have an electronic speedo, tell me what brand and how you got it hooked up please.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-20-2010, 12:42 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS Swap guys! What did you do for a speedo?
gps unit on suction cup mount. i figure its accurate enough for most cruising but you can save the dash space (and expense of either a digi or conversion box) for other gauges.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-20-2010, 01:33 PM   #3
Super73
Super73's Avatar
My laptop or my single borad computer/touch screen and an HP tuners cable. Gives a lot more than just speedo.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-20-2010, 01:45 PM   #4
Clyde65
Clyde65's Avatar
So yall two dont have a "speedo"?
Clyde65
Rebuild of Clyde
support our troops!
Old 10-20-2010, 02:00 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Mine should be no problem since I'm running a 200-4r...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-20-2010, 04:17 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
nope. PO put the sbc in my truck but never got the speedo cable or anything hooked up. I just use the little "stick anywhere" suction cup and my tomtom. They even have a firmware hack/mod that allows you to use it just as a big speedo. Hell, a used tomtom1 goes for like $70; cheaper than a speedo.
Old 10-20-2010, 05:28 PM   #7
67C10BUB
67C10BUB's Avatar
I am going with the Auto Meter programmable speedo, but it's not running yet. Check out my build thread. I will post info on it once I get it running.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-20-2010, 06:41 PM   #8
mrhino
I went with Classic Instruments. Its electrical, controlled by the pcm along with the Tach.
mrhino is offline   Reply With Quote
Old 10-20-2010, 08:56 PM   #9
TR65
TR65's Avatar
I use a CableX box mounted just below the fuse box and a short cable they made up for me. The setup works good but it is still a mechanical speedo.
But what I really use for driving is a scan gage, velcroed just under the speedo. You can set it dead accurate with a GPS and know exactly how fast you are going. (It also displays any 4 quantities that are on the serial bus, I usually run speed, RPM, Fuel level, and water temp.)
http://www.scangauge.com/products/
I also has all the trip functions, MPG functions, you can even make up new gages.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 10-20-2010, 09:15 PM   #10
clinebarger
Im running one of these on my Suburban http://www.transmissionpartsusa.com/...4l60e%2098.htm.
clinebarger is offline   Reply With Quote
Old 10-20-2010, 11:02 PM   #11
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I used a factory 90-91...maybe 89 suburban cluster... had an electronic speedo. in a nutshell repin the cluster pigtail, and to make the speedo work its a power, ground and vss (wire comming from pcm) Those are all apart of the PC board on the cluster. I think I have an extra one in the garage... i wont know untill saturday for sure.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-21-2010, 01:28 AM   #12
78bronzechariot
78bronzechariot's Avatar
I went the not so cheap route Dakota digital gauges specifically for 67-72s. Hooked it up to the speedometer pulse wire from the pcm, set the control for the speedo to "learn" mode and drove a measured mile.
78bronzechariot is offline   Reply With Quote
Old 10-21-2010, 10:28 AM   #13
Clyde65
Clyde65's Avatar
Thanks guys, I appreciate your input, Mrhino, how is you Classic speedo hooked up? PCM wire or at the VSS?
I am concidering going with an Autometer electronic speedo and see if that thing works.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-21-2010, 12:42 PM   #14
MONTEZ
I plan to use a set a lavorsi CAN signal gages since they will plug directly to my ECM.
http://www.livorsi.com/catalog.htm
For the guy who posted about using his GPS as a speedo, Livorisi offers a GPS speedometer
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 10-21-2010, 12:53 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ouch EXPENSIVE^^^
I do like the idea of the scanguageII tho. I had the regular Aeroforce Scangauge in my SRT4 and it was great.
Maybe i will lose the GPS for a scangauge this xmas.
Old 10-21-2010, 04:20 PM   #16
mrhino
Mine uses the PCM signal and then into a "Speedometer Calibration Module" it takes the 4000 pulse per mile signal and converts it to a signal the speedo can read. (16000ppm) I believe the Autometer speedo runs off of the VSS, but im not sure
Old 10-22-2010, 10:28 PM   #17
TR65
TR65's Avatar
Here is a pic of my setup. All of the stock gages work except you can see that the temp gage is wrong. I am determined to get it to work with the late model sender, but I have not beat it yet.
The scan gage is showing speed, rpm, fuel level, and my average mpg for the trip to work this morning. The mpg is calibrated in the scan gage to give the accurate value.
TR
1965 C10 SWB Fleet
Two owner
