Old 10-20-2010, 11:33 AM   #1
theslawdawg
theslawdawg's Avatar
Strange sound when turning right
Okay,
I thought I was hearing things but this morning I confirmed it. I noticed when I was taking a right turn (around a block), I hear a distinctive "Rat-tat-tat-tat..." sound. Once I straighten her out, the noise is gone. It does not happen on left turns, and it does not happen at very slow speeds (like when I'm parking the truck). I'm not taking the turn super fast either, my speed is probably between 15-25 MPH when I take the turn. Any ideas? Thanks in advance...
1972 Chevy C10
theslawdawg is offline   Reply With Quote
Old 10-20-2010, 12:12 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Strange sound when turning right
Weird thing about noises....they're hard to nail down when you're behind the wheel.
Some shops have a noise detector that places microphones on all four corners so they can help pinpoint the area. It's a suggestion.
Member Nr. 2770
Old 10-20-2010, 12:42 PM   #3
geezer#99
geezer#99's Avatar
Check your wheel bearing. Jack up that wheel and see how much play you have in it. Grab it at the top and bottom and wiggle it. Could be a bit loose and shifts to the side when you turn and contacts the disc pads.
geezer#99 is online now   Reply With Quote
Old 10-20-2010, 12:50 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
LOL Join Nascar and turn left ALL of the time.
Frank
piecesparts is offline   Reply With Quote
Old 10-20-2010, 12:57 PM   #5
rollinhard
rollinhard's Avatar
Could it be your rear diff. Gov lock might be broken they seem to make funny noises when turning right more then left I found. Don't know why must be in the mechanics of them just an idea.
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 10-20-2010, 03:30 PM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Does the noise change with engine speed or vehicle speed?
Zoomin is offline   Reply With Quote
Old 10-20-2010, 04:30 PM   #7
GOPAPA
GOPAPA's Avatar
I had a noise like tic tic tic when turning in my 65 chevy pick up and it was the posi traction .
GOPAPA is offline   Reply With Quote
Old 10-20-2010, 05:08 PM   #8
theslawdawg
I only notice the noise when I make turns around a street corner (90 degree turns). I have not tried to purposely speed up or slow down. I did try to hear for the noise when I pulled into a parking lot (at an obviously much lower speed) and I did not notice the noise.
1972 Chevy C10
Old 10-21-2010, 10:23 PM   #9
theslawdawg
Talking Re: Strange sound when turning right
Well, I jacked the truck up and checked my tires. My front left tire jiggled and we confirmed that the wheel bearing needs replacement. I will do the uninstall/install tomorrow and will attempt to take pictures as I go. Thanks everyone for their help on this one.
1972 Chevy C10
Old 10-21-2010, 11:29 PM   #10
1969stepside
1969stepside's Avatar
the power steering pump could be going bad too just a thought
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
