Old 10-20-2010, 12:40 PM   #1
kvn1011
Kvn1011
kvn1011's Avatar
Lightbulb msd box,intake manifold,carb LQ4, motor mounts, th350 adapter
Can you please add anything that i may have left out for a carb set up, thanks!!
assuming the engine will be stock for now, what else would I need?
kvn1011 is offline   Reply With Quote
Old 10-20-2010, 02:05 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: msd box,intake manifold,carb LQ4, motor mounts, th350 adapter
fuel pump and regulator, exhaust manifolds/headers, intermediate pipe or complete exhaust, accessory drive and components, any hardware, etc. (cause there's always something )
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-20-2010, 02:38 PM   #3
kvn1011
Kvn1011
kvn1011's Avatar
ok, perfect i plan on taking the plunge pretty soon!!
thanks!
Old 11-02-2010, 03:40 PM   #4
kvn1011
Kvn1011
kvn1011's Avatar
waiting on delivery now 2005 denali 88,000 miles all accesories etc
now i want to go carb'd msd 6010 and victor jr 29085, are these the correct part numbers?? i plan on ordering them today
thanks kevin
also at http://teamc.com/
i found the msd box @267.00 and the victor jr ((assuming i have correct p/n priced @329.00 ) just making sure i have the right parts to get started, then as money allows ill get the other pieces
thanks kevin
Old 11-03-2010, 10:08 AM   #5
Shon
thanks kevin
thanks kevin
Is that shipped prices? I am trying to help you out....going to that website it is not a shipped price. I am checking on availability and see if I can get you the parts at the same shipped price or less....
I have the crank spacers if you need them for $45 shipped
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 11-03-2010, 11:17 AM   #6
Shon
I will ship the 29085 for $350, teamc wants $353.xx
In stock and ready to go.
the MSD unit is back ordered from MSD and should be ready 11/15.
Old 11-03-2010, 12:12 PM   #7
kvn1011
Kvn1011
kvn1011's Avatar
Old 11-06-2010, 08:56 PM   #8
kvn1011
Kvn1011
kvn1011's Avatar
ok here is a th350 via google
and my LQ4
from the looks of this would i just need to elongate the holes circled in red on the flexplate of the Lq4??
Old 11-06-2010, 10:46 PM   #9
clinebarger
You have to buy a spacer. A TH350 converter pilot (black circle) is not long enough. DO NOT just redrill the flexplate....If you do the converter will be "off center" in relation to the crankshaft, This will ruin the converter & the front pump in your transmission.
clinebarger is offline   Reply With Quote
Old 11-07-2010, 12:37 PM   #10
kvn1011
Kvn1011
kvn1011's Avatar
ok, That makes perfectly good sense!!! seeing it and reading it to me makes a world of a difference!!
thanks clinebarger!!
i was researching on my own and found this, it will help those who may need both spacer and fly wheel.
it comes with flywheel, spacer and bolts at $50 all new from GM.
http://www.gmpartsdirect.com/results...umber=12621399
With this GM part number 12621399 you get everything.
Old 11-07-2010, 03:16 PM   #11
68GMCCustom
I bought an everything kit from Pace for my 200-4r. The flexplate that was supposed to fit didn't match my torque converter or a t350 from what I could determine. The converter pilot fit so well though into the machined spacer into the flexplate, nice and tight. Considering I had bought a spacer and later realized I would still have to get a new flex plate...so I just bought this Pace kit. When it fit nicely but the holes were a bit off.....I drilled it. This made the mounting holes elongated but due to the pilot fit I felt since it was centered so well, that even though I wasn't using a drill press...the end result with a small equal amount of metal removed would be a good working/centered/balanced fit.
In this circumstance.........is my flexplate now junk? I bolted it to the converter using ARP bolts. No nuts were required for my flexplate as it had like captured nuts welded to the tabs. I was considerate to balance in my mod....but couldn't gaurantee its as good as a "proper" flexplate would be.
Kurt -
Old 11-07-2010, 05:57 PM   #12
clinebarger
Thats a really good deal, That is what GM uses to mate a 4L80E to a 6.0 in 2500HD & up trucks. I have priced out that kit in the past....It cost alot more than that at the time. Are you sure its not just the flexplate at that price?
I think it will be fine. Thats what Advanced Adapters does, Crank spacer and a redrilled stock flexplate.
Old 11-07-2010, 11:26 PM   #13
68GMCCustom
thanks! I'll be hitting it with some HP and don't want to have to walk home from the race track.
Kurt -
Old 11-08-2010, 04:14 AM   #14
kvn1011
Kvn1011
kvn1011's Avatar
Yep I googled that part number and there are several forums explaining the same use......... see below link
http://www.pirate4x4.com/forum/showt...php?p=10063967
Here is the google results link.......
http://www.google.com/search?q=12621...ndroid-verizon
And a seller with same part number with higher pricing and description
http://www.crateenginedepot.com/stor...P2399C120.aspx
And one of many forums that talk about the application
http://forums.corral.net/forums/show....php?p=9410073
Old 02-04-2011, 09:59 PM   #15
BigShoe24
True Addiction
BigShoe24's Avatar
Hey Guys, I just bought an LS376 / 480. I believe this is the piece I need in order to hook up to my 4L80E. Any confirmation or recommendation would be greatly appreciated. Don't mean to hijack the thread.
Thanks, nice work kvn
RCC
BigShoe24 is offline   Reply With Quote
