12-17-2001, 07:21 PM | #1 |
77 1/2 ton 4x4 question
Hey y'all,
I got some questions about my truck.My truck has the "auto" hubs on it, does this mean it has a 203t-case? When i turn my wheels either left or right and get the gas it tries to "walk" or "wobble"( like when you lock in and turn real sharp) except i don't have to turn sharp. A decent and it will do this,I really like the 4x4 set up all i got to do is throw it in 4H and all 4 seem to pull, but when in 2H it seems to pull in the front axle. is this possibe? My dad said that some K10's were like this, I know i cleaned the T-case and it had C/K 10 wrote on it with some sort of paint.Could'nt find anything that said 203 or anything I was just wondering if the walking was something to be conserned about or if it was just the way these trucks was with auto hubs. Thanks conoverbandit
71 GMC 3/4 ton converted to dually 75 chevy swb 4x4 78 pontiac trans-am----sold, so long old friend..... 87 Crew Cab 2x 454 93 chevy hi top conversion |
12-17-2001, 10:18 PM | #2 |
Its sounds like you have a 208 t-case. The 203 didn't come with atuo hubs or a 2WD feature. And the 205 had manual locking hubs. Check to see if you have a aluminum case. If so.. its a 208.
To fix the front end from walking is to change out the auto hubs and replace with some manual locking hubs. This will let the tires run more freely and will save wear and tear on the drive train and save money in the long run. Also, in my opnion.. Both the 203 and 208 are just plain junk!! 205 t-case is the way to go. For strenght and very dependable. Hope this helps.. Rock on people!!!! ------------------ 74 Chevy K-5 Blazer. 565 Tall Deck Big Block Chevy, 4.5 bore, 4.50 stroked crank, 10 to 1 pistons that are 60 over, aluminum heads with full rocker cam and lifters. hooker heads with 1 7/8" primary and 4" collectors to a pair of flowmasters. 4spd auto, 205 T-case, Dana 60 front limited slip, Corp 14 bolt rear lockers, with 4:88. Working on a 4 link coil over spring front suspenion with 63inch leaf link rear suspenion. Running 38 Ground Hawg tires on custom 16.5 bead locked rims. 8 point roll cage and lots of other goodies. Its my money pit land boat, but I love it!!
I'm the third owner of this 74 Chevy K-5 Blazer mostly stock back in the day. Since the start of the build up the truck now has a 540 Tall Deck Big Block Chevy, 4.5 bore, speed-o-motive 4.25 stroked crank, 10 to 1 pistons that are 60 over, 800 CFM performer carb on a 454-0 aluminum intake, Brodix 2X aluminum heads with full rocker cam and 7:1 lifters. hooker heads with 2" primary and 4" collectors to a pair of flowmasters. A preped 700R4 rated to 700HP, 205 T-case, Dana 60 front limited slip, Corp 14 bolt rear lockers, with 4:88. Working on a 4 link coil over spring front suspenion with 63inch leaf link rear suspenion. Running 38 Ground Hawg tires on custom 16.5 Trail Ready bead locked rims. Custom dash with Auto meter gauges, Bear custom seats, 8 point roll cage and lots of other goodies. Its my money pit land boat, but I love it!! |
12-18-2001, 12:24 PM | #3 |
My t-case is all metal,looks like cast iron.
got k-10/20 on top of it looks like some sort of marker or paint. It has 2 wheel lo/hi and 4 wheel lo/hi if this helps any.Thanks ,conoverbandit
12-18-2001, 01:56 PM | #4 |
Strongman Garage
if its cast iron its a 203..... you can convert it to partime
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
12-20-2001, 07:52 PM | #5 |
Sounds to me like someone put a junk yard(the yellow paint markings)205 in a full time 4X4 truck,Is it possible a previous owner did that.I've never seen a 77 with auto hubs.
------------------ -69 CST/10 350/400TH -79 K20 4x4 350/350TH -75 Maverick 302 C4 Sheridan,IN [This message has been edited by jeff46069 (edited 12-20-2001).] |
12-25-2001, 09:37 PM | #6 |
Teufelhunden
no cause he said the case has 2hi/low and 4hi/low 205 is 4 low N 2hi 4 hi
1971 K10 lwb fleetside 402 T350 205 |
