Old 10-20-2010, 06:19 PM   #1
tek970chevy
steering problem!!!!
i noticed when i was driving that my steering wheel had alot of free play... when its parked, instead of it being stiff or not moving, it still moves... i dont have much knowledge on steering but if theres anybody out there that does..any tip helps.... thanks
tek970chevy is offline   Reply With Quote
Old 10-20-2010, 06:23 PM   #2
gearys 5600
gearys 5600's Avatar
Re: steering problem!!!!
Check your steering gear box for play, Also check your tie rods and pitman arm.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-20-2010, 07:28 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Check the gearbox adjustment as gearys mentioned. There's an adjsutment you can make there but don't overdo that adjustment. They rarely become maladjusted on their own. If it's real loose, then there is probably worm gear wear and may need to be replaced.
If the play is not in the gearbox, then I would take it in to a front end place and have them check the tie rod ends and ball joints. They have a special tool they use to see how worn they are. That's usually where most of the steering wear will be on these old trucks.
68gmsee is offline   Reply With Quote
Old 10-20-2010, 08:50 PM   #4
Mike J
vw guy & now c-10 guy
Mike J's Avatar
yeah, look at the pitman arm- I had replaced nearly every part in my front end besides that piece when I did the drop and then found I had excessive play in the pitman arm link- I could wiggle the steering shaft and watch the arm move back and forth...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 10-20-2010, 11:24 PM   #5
Mondo
Mondo's Avatar
Probably steering box... pretty common
Mondo is offline   Reply With Quote
Old 10-21-2010, 06:44 PM   #6
tek970chevy
its not the pitman arm or tie rods..... how can i adjust the gear box?
Old 10-21-2010, 09:59 PM   #7
70cst
70cst's Avatar
If its the steering box...time to rebuild or replace. I think.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 10-22-2010, 09:49 AM   #8
RustyParts
RustyParts's Avatar
Don't forget to check the shaft coupler joint. It could be worn out.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 10-22-2010, 09:58 AM   #9
cdowns
cdowns's Avatar
improperly adjusting that screw can cause catastropic failure at the worst possible time// read about it in factory service manual for proper way to do it for safety
Old 10-22-2010, 11:16 AM   #10
68gmsee
Active Member
68gmsee's Avatar
A quick search and I found this that may help.
http://www.chevytrucks.org/tech/steering_box_adjust.htm
forgot to add: As cdowns mentioned acquire a manual because the adjustments can be critical if not done properly. Just remember that this and the brake system is probably the most important thing to make sure is working right.
