10-20-2010, 08:42 PM | #1 |
Crazy gas gauge - is it the gauge or the sender?
The gas gauge on my '73 is constantly changing levels regardles of what is in it, even if I'm parked on a level surface. It never pegs completely to one side or the other, so I'm guessing it's not shorting out somewhere.
How do I know if the gauge is bad or the sender in the tank is bad? If the gauge turns out to be bad, can I steal the good one out of my '79?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
10-20-2010, 09:25 PM | #2 |
One shot, one kill.
Re: Crazy gas gauge - is it the gauge or the sender?
21, A 46 ohm resistor should center guage. I use an old volume control. Wire to sender grounded should read empty. Open circut will go over full. Make sure the tank itself is well grounded. Chances are it's the sender, but dash guages do fail. Don't overlook the wireing under the truck, especially if it has dual tanks. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
10-20-2010, 10:41 PM | #3 |
The one in my 74 bounced alot but it appeared to actually be changing w/the level in the tank (fuel slosh when moving down the road). If the truck was sitting still & the gas/liquid was still, the needle was still.
Is your gauge needle moving even if the truck has been perfectly still?
10-20-2010, 11:09 PM | #4 |
Yep, just warming up in the drive way I can go from half a tank, to a full tank, and then back to a quarter, within a few minutes. It moves a lot but not fast enough to keep up with sloshing.
10-20-2010, 11:32 PM | #5 |
Start w/inspecting the ground @the tank.
10-20-2010, 11:36 PM | #6 |
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
10-21-2010, 08:33 AM | #7 |
If you search here you will find several threads on erratic gas gauges. I did a lot of research when my gauge was not working properly and determined that I needed new sending units on my dual tanks. I actually needed a new gauge, so I don't think all of the tests recommeded are 100% foolproof. I suggest installing a known good gauge to see if that helps. Dropping a tank or lifting a bed takes quite a while and can be a dirty job. Removing an instrument cluster and replacing a fuel gauge is a clean .5 hour job. You can buy a new aftermarket gauge for about $50. If it is not the gauge, you might be able to return it. If you can get your hands on a known good working used gauge that would be better for a test. Note: if you replace your sending unit(s) with Spectra brand, your gas gauge will move when your vehicle moves (about 1/4 tank range). However, AC/Delco sending units cost about 3X as much - I'll put up with the moving gauge.
