tie rods maxed out need help
just got done rebuilding the front end on my dually and my tie rod on the passenger side is maxed out. the driver side is close but it will be fine looking down on the front it looks like this / / except not as bad. is this normal there is no more adjustment on the passenger side and the driver needs to come out so it isnt a problem. steering wheel is straight. i cant cut down the passenger side because either way there is no thread left. i hope that makes sense if it doesnt ill try to rephrase
1987 Gmc sierra 1962 Apache 10 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: tie rods maxed out need help
Do you have any pics of what you are talking about?
Are the upper ball joints in a bind also?
Hollister Road Co.
Sounds like you got you ends mixed up. shorts on one side and longs on the other. Shorts should be outer and longs inner.
GM Addicted
did you drop your pitman arm?? if so are you sure you put it on correct. If you moved the steering gear box with the steering wheel you can have misaligned it.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#5 | |
im not positive on that one ill have to double check
