Old 10-20-2010, 11:25 PM   #1
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Transmission Dipstick Tube Leaking
My TH350 has a serious leak at the transmission dipstick tube o-ring where it inserts into the tranny. I bought a Hughes Performance tube and dipstick assembly from Summit but it doesn't fit properly--it needs to be longer. I didn't really want to replace it with an OEM style tube or a braided stainless steel Lokar unit (looks too fancy), but it looks like I'm going to have to go with the Lokar 36" unit. It has a dual o-ring seal and is a firewall mount.
I could fit a replacement o-ring in there but I know these tubes are notorious for leaking. The nice thing about the Hughes unit was that it had a press-in type seal that looks like it performs better than the o-rings, but again, it doesn't fit properly.
Anyone have any solutions to this problem that I could try out?
Thanks in advance,
Mando
TheWhiteElephant is offline   Reply With Quote
Old 10-21-2010, 12:53 PM   #2
hotrodimpy
Re: Transmission Dipstick Tube Leaking
Mondo.
We would love to have you purchase a Lokar product. Our standard firewall mount dipstick is 24" long. We also make a 36" long firewall mount dipstick.
We see this problem quite often. You might want to check the hole in the transmission case. if it is accessable enough for you to measure it should be
.750 diameter. We see these as big as .760 diameter and nothing wants to seal. If you want to go with a stock looking dipstick look for something a little later model with the top hat style lower seal they are much more forgiving in the oversize holes. We also offer a locking transmission dipstick that has the bottom fitting installed into the transmission under compresion. All of our Stainless Steel dipsticks are available in "BLACK" and it kind of blends with the engine compartment. If you have any queations we can help you with please contact our Tech department at 865) 469-7440 Thanks Impy
hotrodimpy is offline   Reply With Quote
Old 10-21-2010, 12:54 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Permatex.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-21-2010, 01:11 PM   #4
3r!c84
Badass
3r!c84's Avatar
Put some rvt around the tube and shove it in and wait for it to seal.. Maybe?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-21-2010, 02:09 PM   #5
Jonboy
Slots go on anything!
What's wrong with the OEM part? They redesigned the tube and dipstick in the late 80's to address the leaking and trans fluid puking problems. The new tube has a boot seal, and works well. The corresponding dipstick has a locking seal at the top to keep fluid from overheating and coming up past the top of the tube. All of the parts needed should be $20-30 at the dealer.
1974 Jimmy- 5.3/4L80e/NP241
