Old 10-21-2010, 05:14 PM   #1
mdazb
mdazb's Avatar
Side window
Searched for a answer for this but couldn.t find one.
Replaceing the rubber in my door and vents. On my driver's side, the main side glass has come out of its channel. in otherwords, it (or it did) fall to the bottom of the door. My question: is the glass glued in the metal channel? I purchased what LMC showed, but its just a 2" wide strip of rubber. I'm thinking it folds or lines the channel and the glass goes between the folded rubber in the channel. Haven't tried it yet but wondering if I need to use some sort of glue.
Any thoughts would be great...
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 10-21-2010, 05:27 PM   #2
ctrow
New Member
ctrow's Avatar
Re: Side window
Supposed to be enough tension between the channel, rubber, and glass to make it seal and stay in place.
You could use a little sealant if you wanted though. Just enough drops here and there to make it stay.
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=366351
ctrow is offline   Reply With Quote
Old 10-21-2010, 05:41 PM   #3
mdazb
mdazb's Avatar
Re: Side window
Thanks for the reply and info.
98 HD Fatboy
05 Honda Element
