Old 10-21-2010, 05:48 PM   #1
steppside69
steppside69's Avatar
Thumbs up disk question
I have been looking around the FaQ http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
I know this post is old but was wondering if anyone could tell me the difference in lca from a 1/2 ton and a 3/4 ton lca.
If there is no difference it would be a good alternative to aftermarket swaps.
And another question, I thought i read that 73 and up spindals work with later model 6 lug disks? I cant remember where at or if it even worked.Any help would be appreciated, Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 10-21-2010, 06:13 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: disk question
The only difference is the 3/4 uses a larger ball-joint. Since it presses in the hole in the 1/2 is too small. The upper just bolts in and is ok. Any '67-87 3/4 lcr would work, I believe. Its just that if you went to say '71-87 I would get the upper to match just so the mounting bushings are all the same.
No one has found a factory 6-bolt that is a direct replacement. The prob. with using those 88-92 (if memory serves) is the distance from the back of the rotor to the inner bearing/seal is different. Thus the rotor does not line up in the caliper.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 10-21-2010, 06:28 PM   #3
steppside69
Re: disk question
By 3/4 you mean 8 lug? Or does 6 lug also qualify? 5 lug is 1/2 ton
Old 10-21-2010, 06:57 PM   #4
70C10Toejam
Hellasick
Re: disk question
The thread you were looking at was on using the "light-duty" 3/4 ton 6-bolt rotors. They were made from '88-'92 and had 6 lugs instead of the standard 8. They used the standard 3/4 ton ball joints, I think.
The ones I have seen had W/T (work truck) after the 2500, like the 1500 W/T's that had the v6's.
Old 10-21-2010, 07:19 PM   #5
steppside69
Re: disk question
I found this post seems to answer my question
http://67-72chevytrucks.com/vboard/s...d.php?t=403713
going to try this
Old 10-21-2010, 07:24 PM   #6
70C10Toejam
Hellasick
Re: disk question
Looks good.
Old 10-21-2010, 07:26 PM   #7
raycow
Re: disk question
One other difference I have noticed between 1/2 and 3/4 ton is the control arm bushings. On 73-up, at least one of the 3/4 tons I looked at still used the older type bushings that have to be greased. Is this true for all 73-87, or was the one I saw just an oddball?
Ray
raycow is offline   Reply With Quote
