Old 10-21-2010, 07:35 PM   #1
sandorjoben
sandorjoben's Avatar
87 v15 Temp gauge & Oil Pressure Gauge
Dear Everyone;
The truck: 1987 v15 350tbi th400
The problem(s): water temp gauge shows nothing, neither does the oil pressure gauge
The oil pressure gauge shows nothing because there is nothing connected to the pressure sending unit by the oil filter (hasn't worked since I got the truck), the wiring in my truck is a mess from POs. I'm probably going to put a new sending unit anyway but I can't find the wire I'm supposed connect to it, what color should it be(Haynes manual says a tan wire but I can't find one) with what type of connector?
The water temp gauge indicated temperature briefly when I first got the truck and put it on the road but then stopped. I put in a new sending unit yesterday and it worked fine for one run but as of this morning I have no engine temp showing again. When the engine starts there is very little needle movement on the gauge(it shakes briefly), I checked the gauge by grounding the green wire connected to the sender and it seems to work(the needle spikes to max temp), I also tried switching gauges with a spare that also passed the ground test and still the same result. The circuit paper for the instrument cluster is also in tip top shape so I don't think that's an issue. Could a sending unit crap out that fast (1 use) or is there another issue?
Thanks tonnes in advance for any assistance.
Dave
sandorjoben is offline   Reply With Quote
Old 10-22-2010, 03:05 PM   #2
sandorjoben
Re: 87 v15 Temp gauge & Oil Pressure Gauge
Before I go and change the temp sender with another replacement, is there a chance that the teflon tape on the sending unit's threads(it came that way from Parts Source) is causing the problem? In trying to find a solution I've seen several write-ups troubleshooting temp gauge issues that say NOT to put teflon tape on the sending unit's threads, if that's the case I don't know why the company that makes the sender would package them with it applied.
Old 10-24-2010, 09:49 AM   #3
sandorjoben
I've tested the ground on the sending unit and it's grounded properly, also checked the sender's terminal for a short so the new sender should be good, gonna check the wire itself next. I also think I may have found the wire and connector for the oil pressure sender, gotta check that also.
Old 10-24-2010, 10:24 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
My temp gauge was working sporadically. I figured out that it was one of the spring clips on the back of the gauge cluster not making complete contact with the printed circuit. I was able to snap it back into place so it was seated all the way. Now it works the way it should.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
