power steering picture
can someone post a pic of the power steering gearbox that has the hoses installed into a engine bay that is completed?
Also, does anyone know the size fitting for the gearbox hoses? |
Re: power steering picture
look at the pics in my build thread and i think you will see mine
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
Here is a picture of mine....can someone tell me fitting sizes on the pic? And can you tell me which one is the return side and which one is the pressure side?
Big Red - Now its a SWB!
#1 is return, #2 is pressure. The only reason I know this is because I changed a pressure line yesterday.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
thanks Jac...when you changed the hose, did you notice if the gearbox fitting was larger that the fitting that goes into the pump itself?
Here is the line that I used, it has some info on the fitting sizes that might help.
