Sofa King Crazy!!
Brake lines not gettin the juice.....
Cannot get the fluid to go to the back brakes. Typical disc/drum setup. I did have the rear line higher than the prop valve but fixed that. Air is coming out the rear bleeders when the pedal is compressed but no fluid. I bench bled the master cyl. All new lines, no crimps in the lines and all seems right. Any thoughts??
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
Re: Brake lines not gettin the juice.....
lots of guys neglect clamping the pin on the combination valves as instructions in the factory service manual states as the proper way to bleed these brakes
Sofa King Crazy!!
Clamping the pin? Is that the pin on the back of the prop valve? My rear brake hose comes out toward the front of the truck, and there is a pin on the back.
Active Member
![]() Join Date: Jul 2007
If you're postively sure that you're not sucking in air from somwhere like a loose connection or crack in the brake lines or rubber hoses (two in front, one in rear) then it could be just a lot of air in the lines. Be sure and not let the master cylinder get low on fluid when bleeding. I usually add fluid over 2 full depressions of the brake pedal.
Also you can loosen the fittings at the master cylinder and work yourself back to see if you can isolate it. |
I had that exact same problem on one earlier this summer. The safety valve in the proportioning block will switch to one side if there is a problem with front OR rear. I ended up having to just really smash the pedal while my wife tapped on the prop block with a hammer. After a bit we heard a popping noise and pressure was restored to the rear. This was all due to a leaking brake line to the rear.
#6 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Sofa King Crazy!!
Alright! Some great suggestions here! My girlfriend watched the thread for me today and called me with updates, what a chick. First issue I discovered was that the lines were backwards from the MC to the Prop valve (see above pic). Also had a couple of connections that were not sealed well. Got all of these problems fixed and bled the system. Had brakes for a little while then they faded. The pedal is still bottoming out and I can't get the front passenger side to bleed out properly. More suggestions???
I've had to put a cheapy hand vacuum pump with a hose on the rear lines to the wheel cylinder at the wheel cylinder and draw fluid to the back, and yes; it may empty the master.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
Sofa King Crazy!!
Tried a vacuum yesterday with little success. Finally got some fluid to run through every line, but not a steady stream. I had the front working and before I left the shop it had no front brakes. The back brakes never did work. All of the lines have been seperated at the connectors and new teflon tape put on. Back to square one? Is there something that I am missing?
![]() Join Date: Sep 2005
stop why did you put teflon tape on the fittings???? the brake lines a re flare fitting that are self sealing. if you put teflon tape on the fitting they will elak and not seal correctly. i'd pull the fittings and remove all the teflon tape and tighten everything back up and go from there
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#11 | |
shouldn't need teflon tape anywhere in a brake system. (flare fittings) Did you change out all the front hoses? old ones can get blocked over time. re bleed the master& open up one wheel cylinder at a time starting @ pass rear & push new fluid shouldn't take too long . could master be bad? hope this helps. cheers, Pat
#13 | |
Sofa King Crazy!!
#14 |
Sofa King Crazy!!
The pin that is on the prop valve needs to be pushed in while bleeding but is it free floating or does the hex head around it need to be loosened?
#15 |
You just push the button. The manual gives measurements for a 'tool' you can make to bolt to the valve and hold the pin down.
#16 |
Here ya go. Make yourself a J-23709...
#17 |
Sofa King Crazy!!
Ok. Made a tool and pushed the pin in and bled all of the brakes again. No luck. Any other suggestions?? I am running out of options and starting to thing that the booster/master or the prop valve is bad.
#18 |
start with the master, make some plugs for the fluid ports, bleed it with them, if the pedal is up and rock hard move on to next front calipers , watch for a good stream when opening bleeders, also watch pistons to be sure a pad is not stuck allowing to much piston travel, should only move 1/16" , next pull drum and be sure shoes are adjusted tight enough and cylinders are not stuck.
#19 |
Sofa King Crazy!!
I have bench bled the master twice, no bubbles at all. I have went through the process several times with no change in the pedal. I pushed the pin in today, no results. After the second time there was front brakes, then they faded away. The back brakes have yet to grip good enough to keep from moving the tire by hand. I do have a good stream on the back. The front calipers are not getting enough fluid to push the pistons, or even stop the tire from free spinning. The pedal just goes to the floor with no preassure. WHAT AM I MISSIN HERE?!?!?! I will take off the drums tomorrow and check out the cylinders and tightness of the pads. Any other suggestions other than take it to a shop??
#20 |
VA72C10
![]() Join Date: Mar 2008
bump for answers because I don't have any
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#21 |
I have seen cases where the "check ball" piece in the proportioning valve got stuck. This is evident by the brake light getting stuck on. With the pin clamped and enough bleeding and some gentle taps on the valve I was able to center it again.
Is your brake light on? Does the brake light work? Are your back brakes adjusted properly? The shoes should slightly drag with no pressure on the brake pedal. With the rear tires in the air I like to adjust the rears until there is some resistance in the spinning wheel. Have your girlfriend get in the driver's seat and push HARD with both feet on the brake pedal while you run around and look at EVERY connection for leaks. That is all I can think of right now.
#22 |
if you have a pedal than it's gone, you have a leak somewhere, thats allowing air back in..
is there any cracks in the flares? if you made lines you did double flare.. you did use copper washers at the front disc calp to rubber line bolt.. the master could be sucking in air.. you blead the master , and plug the ports with plugs ( they make flare nuts with no hole for the line, (or make two) got a pedal, good walk away.. in an hour does it? if so the master fine.. next,, sounds line you have a crushed line,, that slowly let fluid therough, and you get a petal. then it slowly bleads out to the rrest of the line. and then no petal.. good luck. |
#23 | |
Sofa King Crazy!!
#24 | |
#25 |
First is everything plumbed correctly? From the photo it appears you have the front bowl plumbed to the rear output of the prop valve and the rear to the front output. It would also appear that the front bowl is the larger and should be plumbed to the front brakes.
http://67-72chevytrucks.com/vboard/s...d.php?t=184148 I looked thru your build thread (nice work) and it was hard to see everything around the prop valve and master cylinder. Some pictures would be nice. Second do you have a long enough push rod in the master cylinder? Sometimes over looked. Understand how those vacuum pumps work. Basically you create a vacumn in a bottle and when you open the bleeder it sucks stuff out, Only after doing this for hours will you effectively pull all the air out if the air is near the bleeder. A pressure bleeder is by far the best tool for forcing fluid thru the lines to create a steady stream. Third adjust the rears until they really drag good. Remember spinning the wheel by hand and feeling a drag is different than a 3500lb vehicles idea of dragging. How much of this bleeding has been done with the vehicle running and pulling a vacumn? I suspect by your statement earlier on that the peddle fades leaves me to believe your master cylinder has some bad seals, or a plumbing problem Did you buy the master chromed or did someone do it out for you? Did you release the check valve after you bled and before you tested the system? If you have no leaks you are 50% on your way. |
