10-22-2010, 03:15 AM | #1 |
? which shocks do i need.
Hi All. I am just about to order my shocks and i am not sure which ones and also where to get them, here`s what i have,
63 C10 long fleet, Front; 2" drop spindels, slam specialities RE 7`s, 18" hopsters, CPp anti sway bar, Rear; Controll arms, slam RE6 bags, 2" lowering blocks, CPp rear shock relocators, 20" hopsters, Pipe notch, Thanks. |
10-22-2010, 08:09 AM | #2 |
67-72 parts collector,…
Re: ? which shocks do i need.
I would order shocks that would work with a 4/6 or 5/7 static drop.
I like using either Belltech or KYB's.
10-22-2010, 09:23 AM | #3 |
I've used kyb's from early classic for the 4-6 drop on a setup similar to yours without issues.
10-22-2010, 10:34 AM | #4 |
Thanks great help. can you tell me who sells them.
10-22-2010, 12:31 PM | #5 |
10-22-2010, 04:23 PM | #6 | |
Had a look on thier website, could only see a shock kit and that was for a 2" drop, !! |
10-23-2010, 01:50 AM | #7 |
New Member
forget earlyclassic order them from summit,just ordered mine they were alot cheaper(alot)my truck has three inch drop springs and i used kyb gr-2 part number 344068 they work great.
10-23-2010, 09:15 AM | #8 |
Redefining LowBudget
read though my build and you may find that what I did on my 70 will work for you and you maybe able to order locally ..I beleive the # is Monroe 5758 off a 50 chysler....I have over 10k miles on them and no problems
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
10-23-2010, 12:09 PM | #9 |
New Member
when i ran the 5758 monroe number at pepboys they said it was a 70s ford car shock and would not work because of the ends,but you never know they could be wrong, both kybs to my door were 47.00$
10-23-2010, 12:48 PM | #10 |
Crap I should write down that # since so many ask....just ask for a shock for a 50 chysler when the # comes up it will be very close to that one..sorry for the bad info
