Old 10-22-2010, 09:36 AM   #1
MONTEZ
Need tubing measurements.
Can anyone tell me the actual external demensions of 2x3x1/4 tube stock? I'm trying to sketch something, but don't have a piece to measure. Also if you know what the corner radii are that would be great!
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 10-22-2010, 12:24 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Need tubing measurements.
Unlike lumber dimensions, metal tube is the actual outside dimensions. 2"x3" would be the outside. 1/4" thick metal, that would affect the inside dimensions. It would be 1.5"x2.5". Sorry, no help on the corner radius.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-29-2010, 12:01 AM   #3
Captainfab
60-66 Nut
Typically the radius of the outside cornere of square or rectangular tubing is 1/2 the wall thickness. So for .250 wall tube the outside radius would be .125. I don't know if this is an actual steel spec, this is just what I have observed over the past 30+ years of fabrication.
Old 10-29-2010, 03:19 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I've gotten 2x3 with tight sharp corners and rounded wide corners, I think it depends on the country it milled in.
dwcsr is offline   Reply With Quote
Old 10-29-2010, 04:13 PM   #5
MONTEZ
I ended up going with a .1875 Radius and it worked out well.
Too bad I changed my mind and am designing another setup now
