Old 10-22-2010, 11:40 AM   #1
Chris65GMC
Exhaust Manifolds
Hi Everyone,
Does anyone know if "rams horns" manifolds fit tighter than a 80's style rear exit truck manifold? I picked up a set of manifolds from a 80s truck thinking they would fit no problem but......they dont! I don't know if the engine was mounted weird or what. Its a chevy 350 but I have a GMC that came with the big six. I'm running headers now but would like to switch to manifolds without remounting my engine.
Does any have any ideas?
Thanks!
Chris
Chris65GMC is offline   Reply With Quote
Old 10-22-2010, 12:52 PM   #2
raycow
Re: Exhaust Manifolds
Rams horns were stock in our year trucks, so they have to fit as long as your engine is mounted in the stock location. If you have moved the engine forward, look at the 67-72 type with the rear-angled outlets.
Ray
raycow is offline   Reply With Quote
Old 10-22-2010, 02:38 PM   #3
Chris65GMC
Thats the problem, i don't know if the motor was mounted in the stock location.
Old 10-22-2010, 03:14 PM   #4
raycow
You can use the 67-72 manifolds if the engine is in the stock location or moved forward. Those would be your best bet if you aren't sure about the engine location. The manifolds won't be a problem if you are having pipes made to fit anyway.
Ray
Old 10-26-2010, 08:07 AM   #5
Chris65GMC
Did these trucks come with the dumps that go straight down or on a angle?
Does anyone have a good picture of their manifold in relation to the frame and crossmember? I want to see how far off my engine was mounted.
The later model manifolds I got are too fat and hit the frame before they can be bolted to the engine.
Thanks,
Chris
Old 10-26-2010, 09:20 AM   #6
raycow
60-66 outlets point straight down. 67-72 are at an angle. Either type will work in a 60-66 if the engine is in the stock location (rear holes on the frame rails). If you move the engine forward you must use the 67-72 manifolds.
Ray
Old 10-26-2010, 09:40 AM   #7
Chris65GMC
Thanks Raycow!
