Re: got an 82 truck with an 88-94ish steering wheel
You can get this from orilleys on the help section shelves, or a junk yard.If the round piece that this fits into is also broken...you'll have to replace the horn disc also as it will be the tab shaft that usually will be broken, After removing the steering wheel, the lock plate and then you'll see the horn disc, it will have electrical contact grease on the brass part. Remove and replace as you see the parts that you taken off.
#3 | |
One day...
![]() Join Date: Apr 2008
Oreillys is charging you shipping?? I would ask where they are getting it from and buy it direct.
Chris
says on their website normally stocked, doesn't say special order when I seen it.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
yeah if you pop in your zip it comes up as not in stock. and yeah $5 shipping!
Old Skool Club
![]() Join Date: Jun 2001
Checked with NAPA? I normally shop at 0'Reilly's but I'm not going to lock myself into them or nobody else. NAPA has a lot of parts at their ready. You might have to wait a day or two for the warehouse to ship it to the store, but that's just part of the sale.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Chris
normally if you go to the store and they order it for you they don't charge shipping, if they do find somebody else. check amazon.com rockauto.com or maybe google shopping, autozone or advance, it might be cheaper or even in stock.
no local b&m shop has it in stock. autozone is special order and advanced has it online for $15. rockauto has it 2.91 and 5.30 shipping. guess i'll just suck it up and have oreilly order it
| Bookmarks |
