Cruzin
i was comealongin the 67 i'm working on, for my wife, on the trailer to haul to my dads. Ready to drop the motor i built in it and saw this. It seems the po before the po (i knew the last one) put a leaf spring adapted to a coil spring rearend in the truck when they did the five lug conversion. MY problem is look at the work!!!!!! welds are horrible i'm not the best but dang this looks like a mess any thoughts? it looks worse in person
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Re: what kind of crap rearend work is this?
looks like that was done with a blow torch...looks about normal when thats what you got to use..try grinding it down and then filling in the surface and spray it with some frame paint..world of diffrence
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
you might want to spend some time checking things out real good prior to putting a motor in it
Bubba
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I am a Referee of life.
FUBAR=Fouled Up Beyond All Redemption.I would just pull it all out and replace/rebuild it before it caused Heartbreak.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Grandpa in the rustmobile...
Looks like shes not gonna make it to manchester in her truc huh? Looks like Id fix it back somewhat right and safe, that looks dangerous!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
What a mess. I wouldn't even think of trying to keep that rear end. Too much work. find the right one reasonable and replace it.
I'll tell ya a story about my '68. I bought it when I was 15, before I knew much of anything. But I soon learned that my rear end looked different than any GM rear end I had seen. It kinda looked like a Chevy car rear from the early 60's because it had a dropout 3rd member with a welded round rear cover. But it wasn't. After scraping around on it- I found a Mopar pentastar in the casting. It was a friggin Mopar rear end! With 6 bolt axles. I thought how could that be? I knew enough to know that Mopar didn't have a 6 bolt pattern the same as GM... so how did they do it? After I yanked it to put a Chevy 12 bolt in, I tore it apart to find out. It had GM brakes, backing plates and tube ends (welded on). And here is the good part- they cut the Mopar axle shafts right by the hub flange, AND WELDED ON GM FLANGES!!!
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
It very well could have been a farm or similar use truck back in the day. Many times things were fixed on the fly, not to have too much down time for the truck. Not like today when these trucks are highly sought after for toys and not work trucks. Sometimes its hard to remember that we have it so lucky today with affordable tig/mig welders and the internet for sourcing the right parts. Back in the day if you had a stick welder and a junkyard within hours drive you might get it fixed...
Maybe what Im trying to say is just be glad you have the skills and the desire to fix it right and not nessarly bash what else someone had to do to get their truck back on the road! |
My Carbon Footprint
Doesn't look that bad.....some people just weld with there eyes closed for safety.
Looks like the only piece of round stock he had for that panhard bar is that old 30 footer laying out back! lol That really needs to come off the center of the diff. Seems like it would affect the articulation of that coil rear end. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Buy a Super Track Bar from Early Classic Enterprises and take that one off.
Super easy to install and adjust. Look here: www.earlyclassic.com
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would definitely build a new panhard bar. There's nothing wrong with it being long like that....less side to side movement through out the suspension travel. I would also suggest checking the other welds, as well as dimensions side to side and the pinion angle.
Cruzin
thanks guys i have the truck out my dads now so i was gonna take the bed off anyways and clean the frame so i will address this also i would like to keep my wife as long as i can
#13 |
if the mounts are welded on too, then a new panhard bar is not gonna fix it all, it needs to be checked, welds and angles
#14 |
it looks like its been done a long time.
#15 |
those welds are more than likely fine,, just not pretty,
redo if you feel you need to.. but your looking as welds that have been there a long time, good luck.. remember pretty welds don't always = good strong welds ![]() |
#16 |
I agree with stich626, but you saw it and we really can't see the welds that well in the photos. One thing to think about is the first thing they teach ya when taking the test to be an AWS Certified Welding Inspector is "you can't bust ugly".
Wire wheel the crud off and then check it out closer. Then take a grinding wheel and grind the welds a bit. If you don't see any slag entrapment in the weld filler metal, and there isn't excessive cold lapping or undercut then it isn't as bad ass it first appears. Maybe post up some additional photos at that point? Last edited by lakeroadster; 10-23-2010 at 04:37 PM. |
#17 |
comealongin ?
1969 C10 stepside 1973 Cheyenne Blazer |
#18 |
Cruzin
yea i'm southern
![]() thanks for the replys guys the guy i bought i from drove it as is (i know him) the main concern for me it the panhard bar just looks off ![]()
#19 |
Do you have pics of the rest of the truck and the engine you built?
#20 |
Cruzin
yes click the link under the 67-c10 in my sig.
#21 |
Six in a row makes it go...
![]() Join Date: Mar 2009
You might want to check the U-bolts down in side the pockets to see how much they rusted. Mine looked pretty good up top but they were less than half the diameter where you couldn't see them.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#22 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
A superbar kit will fix you right up. It will give your panhard bar a better angle and doesn't require welding it in place. Just cut the bracket off that has been welded to your rear end because you will not need it. I wiuld also look into a shock relocation kit if I were you. The shock look like they are layed down too much. (A result of lowering) WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#23 |
Second Chance Program
I believe the ends are old shock shafts.
#24 | |
Cruzin
#25 |
Yup, I wanted to say I remember you saying PO cut the springs lol..
