Truck Junkie
![]() Join Date: Aug 2008
Shocking Problem!!
Has anyone bought a drop kit from CPPJEFF? I bought a complete 4.5/6 drop flip kit shackles springs spindles and shocks for my 85 C-10. Problem is rear shocks are too short! The passenger side top shock mount is about 1 5/8 inches farther away than the driver side measuring to the axle centerline. The bed is off and the axle is square in the frame. I PMed Jeff a couple of days ago, but no response as yet. Could one of you guys measure your mounts and post it up? I'm stumped. The shocks are doesch 4052G and are 15 1/2 extended and 10 compressed. I don't have a fricking clue....Come on guys jump in here and help a GA boy out! Thanks Greg
![]() Join Date: Dec 2008
Re: Shocking Problem!!
i don't have any pics to offer but did the kit come with Shock extenders ? not certain those would help your problem good luck
Truck Junkie
No, the are no shock extenders. The shocks are too short.
#4 | |
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 10-22-2010 at 08:12 PM. |
Truck Junkie
Gotcha GEORGIA boy! better?
Posted via Mobile Device Posted via Mobile Device |
I have some of the same shocks and found that they seemed too short for my truck . I used the stock shocks . Are you trying to install the shocks with the truck at ride height or with the rear springs fully extended . If it is sitting on the ground with the springs compressed and it is still too short , then I imagine you will need different shocks. My drop shocks are still in the boxes for the same reason you mention . My truck is dropped 5 inches in back and they do not work for me .
Frank
Born and proudly residing in a Red State ! |
#7 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Truck Junkie
Thanks f.monroe. You used the stock shocks? Where did u get yours?
#9 | |
Frank
i thought shock extenders provide additional length for your shock absorbers and put the shock at a better angle for proper function. may be wrong tho
#11 | |
Frank
yeller
Are you sure you have the fronts on the front, and rears on the rear? I thought my back drop shocks were too short, turns out I was trying to put the fronts on the back...lol. Switched them around, fit like a glove.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#13 |
Truck Junkie
Thanks bigblock73, the front shocks are shorter than the rear shocks. Now i'm worried the front shocks may b too short as well. Thanks Greg
