Old 10-22-2010, 07:25 PM   #1
O'skool 72GMC
O'skool 72GMC's Avatar
Switching frames frm 2wd 3/4 to 4 wd 3/4
So I just bought another truck and I'm thinking of switching the frame to a 4wd 3/4 from a 2wd 3/4. Anybody done this before? suggestions.
The 72 chevy i picked up is a c20 auto with 402 (see pics)
I'd like to go with a 350 motor and trans with np205 transfer case.
Thanks,
O
O'skool 72GMC is offline   Reply With Quote
Old 10-22-2010, 10:15 PM   #2
Re: Switching frames frm 2wd 3/4 to 4 wd 3/4
The C/20 with a high hump cab is a perfect donor.They use the same cab mounts,if the originals are still good enough to reuse.It's pretty much just a matter of swapping the body onto the K-model frame.
Old 12-23-2010, 02:48 AM   #3
O'skool 72GMC
So the c-20 i picked up is a low hump. Any ideas
Old 12-23-2010, 06:51 AM   #4
JimKshortstep4x4
It is easy enough to change out the low hump to a high hump. I use a plasma cutter to cut out the low hump. The high hump is used to locate the mounting holes and then weld in the weld nuts. Turns out looking like factory.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
