10-23-2010, 11:20 AM | #1 |
Pro Street E - Brake Cable???????
To all of you pro streeters, what are you using for an E Brake cables? I am in the process of redoing my rear drum brakes and I am wondering what everyone is using for that first section of E- brake cable.
10-24-2010, 09:02 AM | #2 |
Re: Pro Street E - Brake Cable???????
Ttt
10-24-2010, 08:51 PM | #3 |
Active Member
I am still using the stock units - I had to fab an eye bolt to the trailing to pull the away from the wheels or they would rub
If you are going to disc simply buy the units designed for the rear that accomadate ebrakes Your other option would be to go to a disc on the back of the tranny or the front of the rear end. You would have a mechancal caliper to lock against the disc to act as your parking brake
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
10-24-2010, 09:13 PM | #4 |
Thanks, You got any pics?
10-24-2010, 11:31 PM | #5 |
Im sorry Im kinda out of the loop on alot of things - what is "pro streeters"?
10-25-2010, 12:04 AM | #6 |
fast car/truck with big balls and some thick meat!!
10-25-2010, 11:30 AM | #7 |
