Old 10-23-2010, 12:55 PM   #1
chevykid65
chevykid65's Avatar
Question 4 spd to automatic
ok so iv been searching the forrums and havnt been able to find out what to do with the 4 speed cross member when you swap in the automatic. i have the t 350 and the crossmember out of a 73 parts truck. i know ill have to move the factory e-brake crossmember. will the 350 fit with the 4 spd crossmember in place or do i need to remove it?
chevykid65 is offline   Reply With Quote
Old 10-23-2010, 01:59 PM   #2
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 4 spd to automatic
Your gonna have to remove it
Your trans MAY fit.....'til you need to do a filter change.
I've heard that some use the e brake xm as the trans mount,but I'd be inclined to beef it up a bit.
there's a thread here somewhere where the guy built one to incorperate the e b with the trans member
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-23-2010, 02:06 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Here's a recent thread with input on the parking brake relocation:
http://67-72chevytrucks.com/vboard/s...=parking+brake
Old 10-23-2010, 05:54 PM   #4
chevykid65
chevykid65's Avatar
thanks you guys. iv been waiting to get started till i could find out what all i had to take out. looks like the 73 crossmember will bolt right up between the framerails so i shouldnt have to do much more than drill a few new holes in the frame.
