Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-23-2010, 01:37 PM   #1
shortbed70
shortbed70's Avatar
broke drag motor...???
Well we tore apart my buddies motor out of his 74 drag truck in progress,and we found a broken lifter,and one lifter that is mushroomed and will not come out of the block of course that lead to flat cam lobe but the delema is where did two bent rods come from.... Needless to say the 355 is becoming a 383 this winter and getting a 4.88 gear and manual vb glide with a trans brake. shooting for the 7,s in 1/8th mile in a full bodied truck.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-23-2010, 05:18 PM   #2
stich626
Re: broke drag motor...???
bent rods are from no oil..
the stuck lifter blocking the oil flow..
what the pick up look like, full of cam chaft lobe
stich626 is offline   Reply With Quote
Old 10-24-2010, 01:00 AM   #3
shortbed70
shortbed70's Avatar
That crap was everywhere. Bearings looked good still so where did the no oil cause the bend.
Troy
Big Red Dog build
Old 10-24-2010, 12:19 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Yeah, if it didn't blacken the bearings I would not suspect an oil starvation,, I'm not seeing how it would cause bent rods tho . My thoughts would be RPM stretching the rod to contact with the head,, or coolant entering the chamber and compression / hydrolock at RPM. Motors do crazy things just as they are starting to come apart.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
