Old 10-23-2010, 02:59 PM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Will a factory 4bbl manifold bolt on in place of a 2bbl?
I have a factory stock 350ci w/factory 2bbl intake on a 72 C-10. I was given a 350ci 4bbl manifold and was wondering if they would swap out or if the heads and/or ports are different? I ran into this problem years ago with a Ford Cleveland 351 and the heads were different from 2bbl to 4bbl manifolds. Thanks!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-23-2010, 03:07 PM   #2
islandboy312
Re: Will a factory 4bbl manifold bolt on in place of a 2bbl?
That's the cool thing about Chevys, great interchangability. As long as it's from the same generation of engine, (1955 to late 80's), it'll fit fine. Linkage and choke are the only issues you might have.
islandboy312 is offline   Reply With Quote
Old 12-11-2010, 02:31 AM   #3
rayfinseats
Pre 86 and after 86 are the main differences. If it looks like it will fit it will. Watch the bolts to the heads. You can see the difference. The newer engines have center bolt valve covers.
rayfinseats is offline   Reply With Quote
Old 12-11-2010, 04:04 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Yep, if its off the same era engine it will bolt up fine.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-11-2010, 05:07 AM   #5
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Gotta love chevy!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 12-11-2010, 06:59 AM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
Just make sure the manifold matches whatever carb CHOKE set up you want to use, that you have the correct carb adapter plate and once you swap it all make sure its not too tall. I have always been a fan of swapping to the front oil fill tube types like found on the 327 and some early 307's.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 12-11-2010, 08:04 AM   #7
rsavage
rsavage's Avatar
If it is a correct quadrajet manifold for our year trucks it will have a divorced choke set up on the passenger side and no egr valve provision on the driver's side. If it doesn't have a carb with it and you want to use what came on it, you will have to look for a quadrajet that has the divorced choke. You can find them on the parts board or on ebay and it should get a rebuild kit before you put it on.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
