grease cap
is it necessary to have a grease cap on the center hub of a rotor? I have ralley wheels and i had bought short snout center caps that say chevroley motor division, and they just dont fit on the front and if i coild take the grease cap off , they will fit. any takers/ THANKS MIKE
Re: grease cap
do you like replacing bearings?
if yes leave off the cap.. you might be able to make the caps shorter.. take and measure the rotor lip that it sits on. and how far the nut and cottor pin sticks past it.. then measure the cap. you might beable to cut it down some and reweld on the top how much room you need, |
![]() Join Date: Sep 2005
Re: grease cap
if you dont have it dust will get in and eat up your wheel bearings. its not a grease cap but a dust cap
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: grease cap
i just took a hammer and smooshed mine down when i had that problem
At the body shop.
Re: grease cap
I had to cut a hole in the cap and remove dust cover on my 77 with the short cap
like these
" That didnt make it any newer " " Dont antique the equipment " |
Re: grease cap
do you have any problems w/o the cap?
Re: grease cap
other than getting dirt moisture and other crap that tends to ruin bearings theres no real need for a dustcap
Re: grease cap
i have 15x10 chrome rallys with those caps and my dust caps clear just fine
Re: grease cap
truckdude, you didnt have to modify them? are they old caps maybe(originals)?
Re: grease cap
