Old 10-23-2010, 08:06 PM   #1
buckshot_86
buckshot_86's Avatar
Need some help with my carb!
Hey guys, i'm having a problem with the quadrajet on my 86, more specifically the choke. Basically, the choke is on all the time, and will not open up. I can manually open it at idle, but once you give some more rpms, it closes again. Do any of you have any ideas? Thanks.
buckshot_86 is offline   Reply With Quote
Old 10-23-2010, 08:15 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Need some help with my carb!
Check and see if the power wire has voltage going to it.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 10-23-2010, 08:28 PM   #3
HOGDADDY
HOGDADDY's Avatar
Yes check to see if ya got voltage then it it does try adjusting it by loosening the 3 screws and turning it counter-clockwise just tad.
HOGDADDY is offline   Reply With Quote
Old 10-23-2010, 08:34 PM   #4
82swampthing
82swampthing's Avatar
you should check your choke pull off also.pull the hose off it and decompress the plunger and put your finger on the hole if it stays in its good and if it goes back out it junk and you need a new one.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 10-23-2010, 08:40 PM   #5
buckshot_86
Thanks! I'll check it out.
Old 10-24-2010, 08:40 AM   #6
tucsonjwt
When you are done fiddling with your choke, install a manual choke - choke problems solved forever - you control opening and closing the choke and by how much.
tucsonjwt is offline   Reply With Quote
Old 10-24-2010, 11:23 AM   #7
mooseknuckles
mooseknuckles's Avatar
I might have to try that also. I tried turning it, but that didn't help.....I just put a zip tie around mine to hold it open
mooseknuckles is offline   Reply With Quote
