![]() Join Date: Oct 2010
horn HEEEELLLLLPPPP!!!!!
So I bought a 72 chevy c-10 that has a non 72 steering wheel on it. I have no idea what year the steering wheel is but some on the 70's board have suggested its an 80's model. I thought I would shoot over here and see if any of you 80's buffs recognize the horn and what I might need to get it to work. When I ground out the little plunger sticking out the horn does sound so I assume I'm just missing the wheels interior. Here are the pics, any ideas?
Re: horn HEEEELLLLLPPPP!!!!!
The wrong style of horn contact is in the second photo from the top.
Where the round metal contact is sticking out, there should be a wire sticking out, that plugs onto the metal electrical tab in the third photo from the top.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
ok so if I buy the contact with the wire will I need to get a different cam? I think what they did was mounted an 80's wheel on a 70's column.
The horn cam should be ok.
Here is a link to a photo with a wire style contact:
http://static.summitracing.com/globa...ac-64200_w.jpg Edit: Another link; http://www.gmpartsgiant.com/componen...2md91fp87.html
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 10-24-2010 at 04:21 PM. |
looks like my wifes s10 steering wheel[90 model]
well i decided to try a rig job just to get it inspected and hooked a wire from the button to the little plunger that is there. I stuck it back on and when I pushed the horn button I could hear the relay click under the dash but no horn. I am assuming this means my horn button is functioning so I bought a new horn at autozone and hooked it up, still no sound other than relay clicking when I push the button, any guesses?
FIGURED IT OUT!!!! I didn't have the horn bolted to the frame when I tried it so the ground wasn't complete. Thanks guys for all your help!
| Bookmarks |
