Old 10-24-2010, 04:24 PM   #1
Ole Greenie
Ole Greenie's Avatar
Rear-End and gear questions
Hey Ya'll...Looking to get a few answers concerning rear gear components.
Situation: 1970 CST S/S with an 12 bolt open 3.08 rear gear set/diff out of a 75 C10. I am looking to change the gear set while installing a posi unit.
While looking around for gear sets and posi units, I have come across some confucing info so I am unsure what to get.
1) I plan to install the 3.73 set with a posi unit but if it is a 12 bolt, but does this mean the number of bolts on the rear diff cover or the number of bolts holding the ring gear in place?
2) Is the ring gear an 8.5" or an 8.6"? Are they interchangeable?
3) Is the pinion gear a 30 spline or 28 spline gear? Which one will I need?
Just seems like GM could have made it all simpler by making a large case and a small case housing and standardized internals except for posi and gear sets. Then you have to take into account a housing for either leaf or coil springs.
Any clarification would be much appreciated. Thanks guys.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 10-24-2010, 05:32 PM   #2
Fitz
Re: Rear-End and gear questions
The term "12 bolt" refers to the number of bolts holding the ring gear to the carrier.
The ring gear for a GM 12 bolt truck rear is 8.875 in in diameter and is not interchangeable with other housings.
The pinion is 30 Spline, 1.438"diameter gear.
Gearsets for ratios from 2.73 through 3.42 use the small carrier. Gearsets for ratios 3.73 through 4.56 use the large carrier. They are not interchangeable.
Go here:
http://www.drivetrainspecialists.com/index.html
you can look up what you need, then buy it anywhere.
Fitz is offline   Reply With Quote
Old 10-24-2010, 05:34 PM   #3
hugger6933
pretty sure that the 12 bolts will have 12 on the cover and the carrier. The 8.5 in ring gear will be a 10 bolt.I also think that the spline count you are talking about one is 10 and the other is 12 bolt stuff. I am positive that if my recallection is off someone will correct me. Jim
hugger6933 is offline   Reply With Quote
Old 10-24-2010, 05:37 PM   #4
cdowns
cdowns's Avatar
it might save you a bunch of money in the long run by taking it in and having a pro do the work
Old 10-24-2010, 06:14 PM   #5
Ole Greenie
Go here:
This is great info! So, since I am running a 3.08 open the best I can hope for is a 3.42...the most gear I can have for my carrier. I'am thinking that this would be a good choice for an LS6 454 mated to a 700R4, since I don't want to turn too many RPMs. What do you think? Much appreciated!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 10-24-2010, 06:21 PM   #6
gearys 5600
gearys 5600's Avatar
12-bolt means- the rear cover has 12 bolts holding it to the housing, 10-bolt- 10 bolts holding it to the housing.
Most 12 bolts have a 3-series carrier, 3.08 ratio to 3.73, But you can run a 4.11 gear or bigger with a spacer ring on a 3-series carrier.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-25-2010, 02:21 PM   #7
Ole Greenie
Any additional thoughts?
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 10-25-2010, 09:35 PM   #8
hayhauler71
hayhauler71's Avatar
Richmond gear makes 3.73 and 4.11 for the carrier you have you just need to read the small print in the adds. With a 700r4 trans i would highly recommend 3.73 gears. Hope this helps.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-25-2010, 11:39 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
What you don' mention is what size tire you plan to run. The height (and width) will also have an impact on what will be your optimum gear ratio.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-26-2010, 04:28 AM   #10
ERASER5
ERASER5's Avatar
Uh no. 12 and 10 are the ring bolts. The cover just happen to be the same number of bolts on a GM12 bolt and a GM 10 bolt. A Dana 60 has 10 bolts on the cover, but it is not a "10 bolt." A Sterling 10.5 has 10 bolt on the cover, but it is not a "10 bolt." Many Oldsmobile diffs had 12 bolt on the cover, but only 10 bolts on the ring gear, not a 12 bolt.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-26-2010, 06:17 AM   #11
Shaky
Six in a row makes it go...
Shaky's Avatar
Setting up a rear yourself includes three basic things: pinion depth, backlash, and patterns.
Pinion depth is the trickiest. Your new gear set will have a number stamped on it. Your job is establish that depth. It is measured from the centerline of the carrier/ring gear and usually requires a special tool. The truck 12-bolt has a crush sleeve to set-up the pinion bearings that's fun to work with too (go a little too far and you have to get another one).
Once pinion depth is established, you bring in the backlash by shimming the carrier either left or right until the "gap" between the gear teeth equals the backlash number.
Then patterns get checked by painting the teeth with pattern grease and then spinning the gear set with a torque applied to the pinion. Then you get to interpret the results.
Maybe you knew this already, but if you didn't you should be aware before you start. I did one for my '66. It took me a long time - but I tend to agonize over this stuff.
Of course I went from 3.73 to 3.08 so we should have just swapped rears instead.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-29-2010, 06:41 PM   #12
Fitz
I can show you a GM housing with 12 bolts in the cover that uses a 10 bolt carrier. Sorta puts a big hole in your theory about bolt count...don't it?
Old 10-29-2010, 07:55 PM   #13
Ole Greenie
Thanks for the answers guys. I sure would like the 3.73 gear set, but I've chosen the 3.42 because I've got the small case and the BB LS6 has plenty of torque at low RPM.
I will be running it on the HWY occasionally for a period od 160 miles each way. ..maybe twice a month. Not that the LS6 gets much better fuel mileage on the HWY but I think a taller gear will be easier for the motor.
Appreciate the help. This board Rocks!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 10-29-2010, 08:05 PM   #14
Ole Greenie
You know, You kind of wonder how these are mass produced at the factory with all this precision! I ompletely understand the precision requirements of all these adjustments. I would rather have a specialist/machine shop install the new gear set to make things easier for me...not to mention they will warranty their work too.
Sure would be nice to find a friend who would be willing to set it all up for an afternoon or two of college football and beer! Y'all take care!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 10-29-2010, 08:41 PM   #15
JJchamp48
So I don't suppose this works the other way, if you have a 4:11 carrier and want to put in a 3:42 gaer set?
Thanks,
Vickie
JJchamp48 is offline   Reply With Quote
Old 10-29-2010, 08:51 PM   #16
Richard H.
Spanked once
Richard H.'s Avatar
I'm tired tonight but I believe you can go to a 373 gear set but that is it. Check with auburn I'm sure that is right.
Look here.
http://www.drivetrain.com/parts_cata...d_pinions.html
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 10-30-2010, 01:31 AM   #17
SSedan64
SSedan64's Avatar
The Carrier determines what gear ratios you can run, not the Rear End housing. If you're changing the Open Carrier to a Posi Carrier you can get a 3 or 4 series Carrier so you can run what ever gear you want.
SSedan64 is offline   Reply With Quote
Old 10-30-2010, 06:07 AM   #18
Shaky
Shaky's Avatar
Well - the factory is making a huge volume of these, so they can justify some exotic, expensive tooling that allows then to do these things very precisely and very quickly.
Guys like you and me are only making one.
Old 10-30-2010, 06:10 AM   #19
Shaky
Shaky's Avatar
Thanks,
Vickie
I don't believe so since they'd have to thin down the gear. As a result it probably wouldn't have enough rigidity to hold the gear tooth tolerances during manufacturing of the gear.
Old 10-31-2010, 06:00 AM   #20
raycow
Probably not enough depth for the bolt holes either.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 10-31-2010, 06:17 AM   #21
Maxxd07
Maxxd07's Avatar
The small case doesnt matter, I got some 3.73 Yukon gears from Randys quite a few years back for my 12 bolt that came with 2.76 gears. They just have a really thick ring gear to take up the extra room since the pinion is smaller. You can get atleast 3.73s or maybe even 4.10s if you want to unless you are set on your 3.42s.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
