Old 10-24-2010, 07:28 PM   #1
LandonL
LandonL's Avatar
Electrical Issue (Please help)
Alright, after the wire burnt up from the alternator to the battery (red one) I went to replace it. I replaced it with 10 gauge automotive wire, and spliced it into the red wire going from the voltage regulator to the cab's clip like it was from the factory. I've gotten everything hooked back up and now when I put the battery cables back on one of them sparks, and begins to melt the terminal. As far as I know I didn't ground out the red wire anywhere, WHAT could possibly be the problem.. This trucks been driving me down the path to insanity..
EDIT:
I didn't change the regulator it's original. What happened was the connection to the alternator(red wire) was loose and it started sparking and the wire heated up and melted the casing all the way to the battery and the truck shut off.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 10-24-2010, 07:33 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Electrical Issue (Please help)
I'm wondering if your regulator has failed? What was the issue before your replaced it?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-24-2010, 07:37 PM   #3
LandonL
LandonL's Avatar
I didn't change the regulator it's original. What happened was the connection to the alternator(red wire) was loose and it started sparking and the wire heated up and melted the casing all the way to the battery and the truck shut off. Could the regulator be causing it?
250 L6 .030 over
Old 10-24-2010, 07:48 PM   #4
shiner2001
shiner2001's Avatar
Indeed.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-24-2010, 07:59 PM   #5
LandonL
LandonL's Avatar
Well, I just unhooked the regulator wires and tried connecting the cables to the battery again..same result. How could it still be the regulator?
250 L6 .030 over
Old 10-24-2010, 08:03 PM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Does your truck still have the junction block mounted on the fender where the lead from the battery hooks to the front wiring harness? That may have melted during the shorted.
Anyway, don't hook up the battery anymore till you trace down the short with a volt meter, or you'll burn the next weak link up.
Zoomin is offline   Reply With Quote
Old 10-24-2010, 08:04 PM   #7
LandonL
LandonL's Avatar
Yes, it has the junction block. No it's still intact it didn't melt.
If I unhooked the charging wire to the battery would this determine if I grounded anything on my new wire setup if it doesn't spark?
How can I find the short with a volt meter exactly, electricity is not my thing. I do have a volt meter.
250 L6 .030 over
Old 10-24-2010, 08:18 PM   #8
LandonL
LandonL's Avatar
UPDATE:
I unhooked the wire at the junction block which charges the battery and hooked up the terminals and no sparks.
I believe I've ruled out the regulator, so what could I have done wrong with my re-wiring?
250 L6 .030 over
Old 10-24-2010, 08:51 PM   #9
Sport/Truck
Sierra Grande Club
UPDATE:
You can trace our steps back using these diagrams.
http://www.boomspeed.com/bofh1968/ch...ng_diagram.pdf
http://www.boomspeed.com/bofh1968/ch...g_diagram2.pdf
s/t
Old 10-24-2010, 09:03 PM   #10
LandonL
LandonL's Avatar
According to the diagram I wired everything correctly..
250 L6 .030 over
Old 10-24-2010, 09:07 PM   #11
LandonL
LandonL's Avatar
Could the alternator possibly cause the problem? I'm not going out to the shop again tonight to check.
250 L6 .030 over
Old 10-24-2010, 09:12 PM   #12
GruntMoanCough
GruntMoanCough's Avatar
I would suspect the regulator, as mentioned above. However, since the wire to the alternator is disconnected and here is no short, I would think the alternator is shorting out. Try plugging the regulator back in. May need a new alternator and regulator now, or upgrade to a newer one.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 10-24-2010, 09:15 PM   #13
LandonL
LandonL's Avatar
Well, when I removed the clip going to the regulator it still caused the terminal to spark/melt. However the wire was still going to the alternator when I did this. So I suspect something in the alternator to be causing this now as you suspected grunt.
250 L6 .030 over
Old 10-24-2010, 09:44 PM   #14
LandonL
LandonL's Avatar
I said I wasn't gonna do it but I went back out there and unhooked the wires from the alternator. Tada, no spark. I'm going to O'reilly's tomorrow to have the alternator tested and if it fails, have it replaced.
250 L6 .030 over
Old 10-24-2010, 11:28 PM   #15
tonypaul
tonypaul's Avatar
Just wanted to thanks for posting those links! Im starting to put in my new harness tomorrow and its going to be a little more easy now figuring out what is what on the old harness...
tonypaul is offline   Reply With Quote
Old 10-25-2010, 11:55 AM   #16
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Sounds like the diodes in your alternator have shorted to ground. Not very common, but it does happen. If it were me, I would also replace the regulator and verify your splices in the harness are not melted as well. Once the wire gets hot like that, it adds resistance and your system will not work as well as it once did. Hope you get it figured out.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
