Can't put into park??
Hey guys and girls...Just got home and my 1997 Z71 will not go into park. I have tried evrything I can think of,but still won't go into park. Any ideas would be great. Thanks in advance, Z
Old Skool Club
![]() Join Date: Jun 2001
Re: Can't put into park??
All Park is, is a pawl that moves into a lock to keep the gearbox from allowing the vehicle to roll.
When I put mine into Park, I press the emergency brake and be sure it won't roll, then put it into the Park position. That takes the load off of the pawl. If that doesn't work, then you may have a mechanical problem preventing it from engaging.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-24-2010 at 09:42 PM. |
Does it not show on the indicator as being in park need more info? It could be the cable needs adjusted or is broke.
laying low
![]() Join Date: Mar 2001
So we can assume it moves into all gears fine but just won't go back into park? Sounds like the linkage may need adjusting. Has the tranny been worked on lately? The brake pedal has to be depressed to move the shifter. Maybe the link between the pedal and shifter has been tampered with or just needs adjusting.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
| Bookmarks |
