Old 10-24-2010, 08:12 PM   #1
avysittinon22s
avysittinon22s's Avatar
Anyway to lay factory crossmember and not arms?
Anyway I lay my factory crossmember and not the arms? If so what arms will work? I currently have 1971 suspension, 3" drop spindles, upper plates, 2600 bags, 27" tall tire.
avysittinon22s is offline   Reply With Quote
Old 10-24-2010, 10:15 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Anyway to lay factory crossmember and not arms?
If you section the crossmember.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-25-2010, 12:00 AM   #3
daverod
SSN 706
daverod's Avatar
I got some pics on page 10 of my build.
daverod is offline   Reply With Quote
Old 10-25-2010, 11:36 AM   #4
tubbedII
needs more $$$
tubbedII's Avatar
On my bro's C10, he has lcas that mount in a recessed area of the crossmember that was cut. They are from Turner Enterprises, which isn't around any longer. The xmbr is also sectioned 1.5" in the pic. I don't know if any other lcas mount this way.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-28-2010, 02:24 PM   #5
cajundragger
I dont see how a section c-member will allow it to not lay arms unless you sectioned it so much so that the frame would lay before. In which you'd be better off z'ing the frame because a c-member drop that big will cause alot of binding issues.
cajundragger is offline   Reply With Quote
Old 10-28-2010, 02:48 PM   #6
daverod
SSN 706
daverod's Avatar
Mine lays frame. 1 1/2 taken out of the crossmember, dropped spindles, orginal arms modified w/bags.
Old 11-01-2010, 10:25 AM   #7
dropd80s
dropd80s's Avatar
Does this set up work good for you? I had a buddy with the same turner set up and it kept the camber positive all the time.
dropd80s is offline   Reply With Quote
Old 11-01-2010, 02:11 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
The truck never made it past this stage. He got the upper arms too which have threaded ends with a lot of adjustment. The camber looks visually good with a lot of room to go either way, but we never measured. If anything though there was a litte negative camber at full drop and about straght up at full tilt.
Once get gets back into the project, he's going to dump it all and get a drop member. There's a modified MII rack on it now for steering, but he doesn't trust it, and figures with the lack of fab skills, it's best to be safe.
1970 2wd Blazer
