10-24-2010, 09:33 PM | #1 |
LED Instrument Bulbs?
Soon I will be ripping out my dash and I was thinking that I could replace my old burned out bulbs with some new LED ones? Hopefully they just go into place where the old bulbs were without having to rewire anything....I would just like some brighter lights than factory and because LEDs look more blue than yellow (and the other lights in the cab will have a soft blue glow). I can't seem to find any anywhere (I think I'm not looking in the right place?) but has anyone else tried this before? and what did you use?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
10-24-2010, 09:52 PM | #2 |
Re: LED Instrument Bulbs?
Went through the same thing in April when I had the guage cluster out for an overhaul. Here's that thread and a couple of other links in it. Started out looking for led's for the cab lights and didn't like the look. But in the dash, perfect for my older eyes!
http://67-72chevytrucks.com/vboard/s...d.php?t=392750 You are correct about the dim oem lights. This is an improvement. Hope this helps. Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." |
10-24-2010, 10:04 PM | #3 | |
10-24-2010, 10:18 PM | #4 |
Slugish
Have blue leds in mine . illumination not any better , but they look cool.
my son got them for me . If you need to the web site pm me. |
10-24-2010, 10:35 PM | #5 |
Originally I purchased 6 of those bulbs for the cab lights, one to have as a spare. Used 5 in the dash and eventually the 6th one goes to the heater light which I managed to forget about until I had it back together.
When you take it apart just look for the light bulbs you have and replace those. Do take care when unplugging the cluster from the harness and remember it won't come out unless you do. Not a big deal, just an important detail for anyone thinking it will "just pull out" after the screws are out. Had that guage cluster apart so many times for this and that and the other at that time I was just glad to have it all working and lighted up. I'd buy 7, maybe 8 to have a spare, and use what you need. Nothing to taking it apart. I had it down to about 5 minutes apart or back together. Phillip screw driver and either a nut driver or small socket. Probably the easiest thing I've done looking back at where I've been so far. Good Luck! Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." Last edited by RuralRoute C-30; 10-24-2010 at 10:40 PM. |
10-25-2010, 12:28 AM | #6 |
In the Forgotten far North.
I wrapped a 48" long L.E.D. strip and four 6" long L.E.D. strips inside the back side of the front cover of my cluster along with white faced overlays to get the look I wanted.
I got all my L.E.D.'s from www.v-leds.com
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
10-25-2010, 10:42 AM | #7 |
Arrived on a Pale Horse
I've got green ones in the dash of the 30 to compliment the factory green interior. I got them from Vleds.
Caution, they are a diode, and will only work in one direction. Plug the cluster in and check them before you put it all back together. If they don't work, pull it out and turn it 180 degrees and check again.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 10-25-2010 at 10:43 AM. |
10-25-2010, 12:07 PM | #8 | |
10-25-2010, 12:21 PM | #9 | |
10-25-2010, 09:28 PM | #10 |
Chevy Enthusiast
I just saw these on ebay a couple days ago. http://cgi.ebay.com/2X-BLUE-T5-509-L...item3f039df69b
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
10-26-2010, 12:50 AM | #11 | |
Salty Sailor
86 c-10 Custom Deluxe Savannah, Georgia |
