Old 01-02-2002, 08:07 PM   #1
84 Chevy
Question Carb to TBI conversion?
I am thinking of getting a TBI motor out of an 87-95 truck to put in my 84 truck when I swap my 305 for a 350. What all do I need to remove form the donor truck to make it work? Is the oxegen sensor located in the pipe or the manifold?
Russ,
84 C10 Silverado truck
Russ,
84 Chevy is offline   Reply With Quote
Old 01-02-2002, 11:41 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
supposed to be in the pipe in the early years. better get the pass side engine harness out of the donor truck, too and the ECM under the dash, etc
A 68 C-10 panel and a 68 dually C-30 dump truck and a couple 71/72 chassis projects.
http://messenger.msn.com
http://communities.msn.com/196772ChevroletCSTsforever
r68c30@hotmail.com
Fast68Chevy is offline   Reply With Quote
Old 01-02-2002, 11:42 PM   #3
Fast68Chevy
Post
and the donor truck fuel tank with pump and lines, etc etc
Old 01-03-2002, 07:06 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
Definately get the fuel pump and gas tanks if you can out of the donor truck. As for wiring the engine, I would use the engine but buy a whole new TBI setup from Holley. www.summitracing.com or www.jegs.com have complete TBI wiring setups that are more modern and will probably out perform the stock TBI. The installation will be easier too. Check on www.ebay.com for a TBI converions book. Check your local library or book store too.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-03-2002, 08:05 AM   #5
Mike_J
Post
Although the Holley system is easier to install, I have been told more than once, unless you get the expensive digital one, a factory GM setup is the way to go. I have done a bit of research on the subject so ill pass on a few bits of useful info.
First, you need to have an electric pump. One way is to get the tank from an '87 truck because that is the only direct replacement for your '84. However, in the late 80's or early 90's fuel injected ford trucks used an electrical fuel pump that was on the frame. I would use one of these (dont tell anybody you used a ford part though!!!). The early TBI's dont require much pressure, what ever year pump you get, I would make sure it is for a ford TBI system.
Take your time with the harness You shouldnt have to cut anything. There is a vehicle speed sensor on an '87 truck that I doubt your '84 has. it is located behind the insturment cluster. You may have to get the '87 wiring harness and insturments too. Im not sure about this, my truck was origionaly equiped with a 4.3 TBI so i dont have to change anything.
Also, all of the parts from the 4.3 are the same as the 350. The only difference is the distribuitor, injectors, ECM, and ESC.
There is a way to wire around the EGR and AIR system too, I dont remember exactly how, I do remember it is very easy. If I find my notes ill post back.
Mike
Mike_J is offline   Reply With Quote
Old 01-03-2002, 07:02 PM   #6
84 Chevy
Question
Will sending units out of the donor truck transfer to my existing tanks or do I have to get the tanks off of the donor truck too?
Russ,
Russ,
Old 01-03-2002, 07:07 PM   #7
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
O2 sensor is on the drivers side just below the exhaust manifold.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
