10-24-2010, 09:40 PM | #1 |
Dana 44 "big hub" hub assembly/spindles
Dana 44 "big hub" hub assembly in good condition. $10 each plus shipping
Dana 44 spindles in good condition. $20 each plus shipping Last edited by 72 LONGHORN; 05-31-2011 at 08:40 PM. |
10-24-2010, 09:45 PM | #2 |
Re: Dana 44 "big hub" hub assembly/spindles
What year are they off of?Do you have the axle number these are off of?Are they 1st or 2nd design,if '72s?
10-24-2010, 09:56 PM | #3 |
special-K, They came off of a 1972. What is the difference between 1st and 2nd design?
10-25-2010, 08:47 AM | #4 |
I can't exactly explain,but the GM parts book lists them as 1st and 2nd design and the number stamped in the axle is what you go by.I had to replace one on my '72 when a lock-out went way south on me.Years ago,when these were available,I replaced one on a '71 because the threads were a bit damaged.I still hung onto the old one and fortunately my '72 was 1st design.You can't find a thread file or die for the oddball pitch GM used,but I managed to dress them with jeweler files and am now running it.I imagine the difference is in the bearing surfaces/dimensions.If I had one off to compare I could help.Maybe another member could help.
10-26-2010, 07:14 AM | #5 |
Did you sell the axle stubs to Sharpie72?Maybe he can help ID them by matching them up.These are rare and not available new.if money was no object I'd scoop them up and figure it out later.
10-26-2010, 07:49 AM | #6 |
special-k, no sharpie72 did not end up buying the axle shafts. burnsman ended up buying them.
11-01-2010, 04:03 PM | #7 |
There were two different bearings available. See pic... Yours appear to be large bearing.
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. Last edited by sakohntr; 11-01-2010 at 04:04 PM. |
11-02-2010, 09:36 PM | #8 |
sakohntr, Thanks for the pic!
11-06-2010, 11:41 PM | #9 |
Are the bearing surface clean on both of the spindles? Thanks, Sharpie
11-07-2010, 09:37 AM | #10 |
Spindle close up pics.
11-08-2010, 10:32 PM | #11 |
Thanks for the pics. I need to confirm which style I need. Thanks, Sharpie
11-10-2010, 01:09 AM | #12 |
Both spindles sold to sharpie1972. Thanks!
11-11-2010, 09:56 PM | #13 |
Still have hub assemblys. ttt.
01-08-2011, 01:51 PM | #14 |
"Junkyard Dog"
Early and late design have the same bearings, the difference is the early (71-Early72) has a conventional lip seal pressed in it which rides on the spindle. The late late design (late 72-76) uses the bellow type seal that fits over the axle stub and seals against the spindle. Should for any reason these are wrong for sharpie1972, I would like a stab at them regardless of style.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 01-08-2011 at 01:52 PM. |
01-08-2011, 01:54 PM | #15 |
tll74, The spindles are already sold to sharpie1972. I do still have the hub assemblys if you are interested in those.
01-08-2011, 04:14 PM | #16 | |
"Junkyard Dog"
Good luck with your sale.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
06-26-2011, 01:07 PM | #17 |
ttt
09-06-2011, 04:45 PM | #18 |
If you still have the Hubs i will buy them. Please contact me at scoutcartel@yahoo.com or 360-620-8427 cell/txt
Thank you John |
09-20-2011, 04:38 PM | #19 |
Hello, you txted me a phone number but the text got erased. Can you please contact me again with your number so i can talk with you about how and where you want payment sent please?
John |
