Old 10-24-2010, 09:46 PM   #1
m6z
m6z's Avatar
GMC Pauls cab bushing kit questions
I ordered the GMC Pauls cab/rad./bed mount kit. Did you have to drill out the washers to fit the front cab mount bolts? Did you use the top washers that were supplied with the kit? I thought they seemed to big. Shouldn't the washer fit down into the recess in the floor? Does anyone have any installed photos of this kit?
Heres the photo from GMC pauls
http://www.gmcpauls.com/pictures/69-...supportkit.jpg
Thanks in advance,
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 10-25-2010, 05:46 AM   #2
JimKshortstep4x4
Re: GMC Pauls cab bushing kit questions
The bolt fits into the recess without a washer on it. (A lot of the bolts were welded at the factory but is not necessary).
Here is a picture of the front mount as installed. There are extra washers, (used as shims) in this picture since the cab was shimmed to match the bed.
I am not sure if these mounts came from GMC Pauls but they are pretty typical.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-25-2010, 08:35 AM   #3
m6z
m6z's Avatar
Jim
Ok thanks. Thats what I needed to know.
Doug
